Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 18 Guests are viewing this topic.
gravityblock
I'll be using these magnets in my upcoming experiments.
Gravock
TheoriaApophasis
TIME TO BUY A PIZZA TOMORROW TO CELEBRATE!!!!!!!!!!!!!   WOOO HOOOOO    MAJOR DISCOVERY TONIGHT!!!!!!!!!!!! using multiple LED frequencies  (R G B) to create white light ONLY ALONG THE DIELECTRIC INERTIAL PLANE with "X DEVICE) !!
[/b]
AND.................I CAN ONLY CREATE ONE COLOR ON ONE POLE AT ONE TIME,  S IS GREEN,  THEN N IS BLUE    ;D  ;D
IF N IS GREEN, THEN S IS BLUE
etc etc
RGB colors exactly all spaced evenly at exact same locations around the cell.
Using magnetic deflection of LIGHT to prove CW and CCW vortex spin EM deflection!!!!!!!!!!!!      AND, RGB concentration (looks like a rainbow) / WHITE LIGHT ONLY ALONG THE DIELECTRIC INERTIAL PLANE
Proves my entire theory  and is a (@*&$(  COFFIN NAIL!!!!!
(too bad I dont drink, or I would have a drink tonight!!!)     ;D ;D ;D ;D ;D ;D ;D ;D ;D
(will post pictures later)
Nobody on earth has EVER SEEN THIS BEFORE!  ;)
93RDELEMENT
Interesting pictures How do you make the image ?????? The lines of force cross over yet do not up set the geometry ????? I don't think those lines are the true magnetic lines to me there something else ! You are not seeing a magnetic picture its impossible like that ! These pictures of another force and If you don't mind there a particle field of some kind ???? To me they are a mono pole set of particles or they will not set up like in the picture ... You can isolate mono poles with ferrite ring magnets but you need to fill them up with water and heat to 80c the temperature of permeability for electrons ...
ARE YOU APSOLUTLY CERTIN THESE PICTURES ARE REAL ????????????
ME
TheoriaApophasis
Quote from: 93RDELEMENT on July 29, 2014, 07:26:05 AM
100% certain
SEE HERE:
https://www.youtube.com/watch?v=dJzECLIVTYI
FIRST TIME ON EARTH ANYONE HAS SEEN THIS DISCOVERY. PROVES:
A: THE MISSING NATURE AND GEOMETRY OF LIGHT AS I WROTE ABOUT IN MY BOOK
B: PROVES CW AND CCW SPIN AND CENTRIPETAL CONVERGENCE BY USING RGB SEPARATION FOR DIFFERENTIATING CENTRIPETAL, CENTRIFUGAL, AND THE DIELECTRIC INERTIAL PLANE
its OVER WITH,   end of story.    Don't believe it ,  DONT CARE
>>>>>>>I only have to PROVE IT, not convince closed-minded skeptical internet trash<<<<<<<
IT IS OVER.         This is my 15th METHOD OF PROOF
It this were a TRIAL and I had to argue my position, it would be already LONG OVER.      ;D
Each little LED emmits R or G , or B, . or combos   OR  "WHITE"  (all 3 at once)
The magnetism and dielectricity SPLITS them up AT EACH POLE depending on CW or CCW vortex....., and  TOGETHER at the inertial plane AND at centriPETAL !!!
ITS "OVER"
d3x0r
I remembered I had this program to play with interlinked rings... was going to use it to model the fields to get a better image of the interactions of a SEG... It does show some similarties with a ferrocell trace.
(a copy of the software, not easy to use)https://drive.google.com/file/d/0B812EYiKwtkkWHZJcXRXVVZqNkk/
Navigation keys.... very rough general documentation of this type of app
https://code.google.com/p/c-system-abstraction-component-gui/wiki/dekwarewhatis
The first 4 sliders control various pitches of the circles plotted...  one of the first 3 sliders must be in a non zero position, otherwise there is no resulting normal for the ring.
On edge it doesn't really match, however the ferrocell is showing a slice inside; tried to watch recent videos in slow motion to catch the transitions better to see if the CW/CCW curve intersections are both associated with the top or one actually evolves from the other side.  Especially during the transition to the side.  Would be helpful to see various levels of approach.... (like 1", 3/4", 1/2", 1/4" .... ) since the only spot that you really allow to evolve into a image is 0" away from the surface... plus the thickness of the glass of the cell.
I tried once upon a time to make a ferrocell but it failed miserably... poor material choice - the glass for picture frames is too thin; or my fluid is too thick maybe..
the clip of on-edge is actually just one copied and mirrored.  The top view is a single side.
Edit: am curios of the 3 (4?) leds.. are blue/green somewhat below the fluid plane?  And red above?  they can't all be exactly on the plane....
Edit2: I guess the mating bowls should be inversed... but then there's missing data in the middle...
Edit 3: stubmled on daniel nunez's POE coils making spiral patterns in plain viewing film... https://www.youtube.com/watch?v=SRNNbglaXA4  (shrug) it's just the field around the windings
