Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 25 Guests are viewing this topic.
TheoriaApophasis
Quote from: d3x0r on July 29, 2014, 08:16:58 AM
Edit: am curios of the 3 (4?) leds.. are blue/green somewhat below the fluid plane?  And red above?  they can't all be exactly on the plane....
See video:
https://www.youtube.com/watch?v=dJzECLIVTYI
Each POLE is diff. color due to inverse spin,  and RGB at the center AND centripetal due to dielectricity.
As mentioned in the book, last section, the missing LINK of ALL light/ electromagnetism is a RADIAL Z-axis DIELECTRIC
This fact:
A; gets rid of the 'wave particle duality" BS
B: DESTROYS the conclusions about the Photo-electric effect.
The TINY LED below emits all 3 colors at once, .....or only R, or G, or B, or combos for diff. colors.     the video shows "white" light only, all 3 colors being emitted.
A ring of them is being used in the video.
We have another device using 3-5 lasers, modulator, beam splitter and few special lenses and are showing COMPLETE MAGNETIC / DIELECTRIC field dynamics    The results are stunningly beautiful, not to mention educational.  Applications are quite a few.
Device is being sought for a patent.
Bob Smith
Ken
Thanks for sharing this discovery with the rest of us.  It's a privilege to be able to see this with you.
You state from 8:08-8:20 that, "this proves that light is not electromagnetic in its entirety, but that it also has a Z axis radial dielectric." For me this is a stunning statement whose implications will shift horizons. Would you care to elaborate on what it means?
If you need to wait, I'll understand.
Thanks for sharing your work.
Bob
d3x0r
Yes all 3 colors are emitted at once, but from 3 distinct points, since they are 3 distinct LEDs.  The package has 6 pins to trigger Red LED, Green LED and Blue LED.
the 3(4?) was because there are some that have a white/yellow LED also to increaase the quality of white... but I see now.  yours are more like the 3 LED models.
"There are three LEDs inside, red green and blue and because they are so close together, they mix very nicely, without the need for a diffuser. The LED is also insanely bright, at a eyeball-blistering 3800mcd."  They would 'mix nicely' from a distance, but with a micrometer thickness the separation can become significant.
And there is a degree of diffusion to it... most of them look like they have a hazy plastic over them... but the light does come from 3 distinct points... actually looks more like 4 areas for 1 and 3 areas for the other... looks like the white bar is directly over the brightest part which makes them be more diffused.
.... and a visual demonstration of what I meant by pleating the LED strip.
TheoriaApophasis
Quote from: Bob Smith on July 29, 2014, 09:20:01 AM
thats in the last chapter of the book, I only gave a brief yet full detailed explaination of same with the intent of expanding that portion.
It means
A: wave particle duality is resolved
B: the explanation of the photoelectric effect is pure BS
It explains the comments from Dr. Oleg Jefimenkos formulas PROVING that E and M cannot be "mutually inducing each other......its IMPOSSIBLE"
on and on and on.
TheoriaApophasis
Quote from: d3x0r on July 29, 2014, 09:22:27 AM
I thought of that bout hour ago and used a translucent diffuser Film
same effect, exactly.   ;D
Theyre so insanely BRIGHT, you cannot distinguish RGB , except as you SEE IN THE VIDEO, at an angle as projected into the lens
the lenses on the edge are ALREADY unpolished / frosted and diffuse the light anyway.
The effects are full circle confirmation.
THAT along with my friends invention which (as I have been instructed not to talk about) will rock the world on its edge.   Ive seen the device in action, its rather "STAR TREK" on its "wow" factor.
Wish I had thought of it    ;D
The light coming from 3 points less than 1mm apart cannot explain the pic below,   there is a RING of 9 of these  RGB LEDs.  ;)
Did I mention that beast 6" magnet hurts my eyes and face when stooped over it and testing it????   :o
