Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: tinman on July 20, 2014, 11:46:41 PM
You cobba are what we here in OZ call a dropkick
Well said.       By the way, I zipped off your videos (the last 2) to some insanely rich (yes, that rich) very very close friends of mine.   ;)  ;)
1 has contacted me already, the other one is in China on a business trip.
send a private PM if you want.
tinman
@TA
Thanks for the offers, but I must decline.
To all-please understand that I only say what I see in my test and experiments, and by no means are making claims outside of what my own tests are showing me-you see whst I am seeing in each test. Of course there could be different results if we set up the test differently-like the electromagnet test. I WILL be doing more on that,but you saw the results of that setup just as I did.
More to come, and all advice by others (except gravityblock) taken seriously
Cheers
Brad
d3x0r
Quote from: Farmhand on July 20, 2014, 10:38:09 PM
How is it that bubbles rising in water the conclusion makes ?
How do we explain the vortexian structures in the smoke and flames of a fire ?  (coriolis)
Or the vortex in the plughole when we let the water out ? (coriolis)
Do they all point to a magnetic field being a vortex as well ? No
If not what does the presence of these other vortex structures suggest to us ?
Cheers
Fire tornadoes in Australian outback. I think I see at one stage the thin smoke is forming a large slow vortex while in the center
there is a thin very fast spinning and fast rising vortex of fire inside it @ 1:22.
https://www.youtube.com/watch?v=lsyvOYcWgcg
Now are we to assume there is an inverted magnetic vortex in the earth wherever there is a wind/ fire or water vortex ?
And a dielectric plane at about the Earths surface level ?
I think fluids naturally form a vortex when it can due to the movement of the fluid. Because it is an efficientway for it to happen,
just as water will find the easiest route down a hill a fluid will find the easiest way to rise "smoke/fire/bubbles" or
fall "water down a sink hole".
most are examples are coriolis effect http://en.wikipedia.org/wiki/Coriolis_effect
But that doesn't account for the spin around the magnet, otherwise the effect would be seen with just a block of metal.
Although I do wonder if being a hollow pipe defeated the electromagnet... much like a magnet with a hole in the center has an opposite pole in the hole.
http://physics.stackexchange.com/questions/16712/hole-in-the-disc-shaped-magnet
with the magnet with the hole used in the first demo the hole was smaller and probably played less of a role.
physical demonstration that's not very good...
https://www.youtube.com/watch?v=zAPeN-6sHUg
Attached image shows field lines from a ring magnet... leaving the north pole and entering the south pole happens on both the inside and outside, which makes magnets both inside and outside flip as if there's a south pole instead of a north pole beyond the material of the magnet... I guess the best demonstration is bedini 'virtual' south poles as indicated when talking about a monopolar motor...  inbetween ANY two norths is a south.
(somewhat related, but starting to be digressive)
If a spherical magnet is put on a metal plate, it will balance so there's a north/south parallel to the surface of the plate, making the strongest binding... the flat rubber magnetic sheets used for truck decals and refigerator magnets have lots of north/south lines in them, which gives them the strongest binding force, and provides most stability in the weak material by actually having a south inbetween each north... the thickness of the sheet determines how wide these are...
The south is felt most within the top/bottom boundary of the magnet, which in a fluid it will definately experience.... moving a magnet outside of this region will make it seem as if it's an all-north face, but with a thinner outer boundary and smaller sensing magnet, there is a flip outside of the material of the magnet (above)
Edit:(oops arrow on right side, bottom is going the wrong direction) *shrug*
Edit2: did find an image reflecting the opposite pole in the middle of a ring magnet that's more artfully drawn.
d3x0r
gravityblock
Quote from: tinman on July 20, 2014, 11:57:26 PM
@TA
Cheers
Brad
Maybe you'll take what I say seriously when you see the electromagnet wrapped completely and tightly in aluminium foil start rotating like the conductive nickel coated neo magnet.  Or, see how a non-conductive ceramic magnet doesn't rotate like the electromagnet without a conductive coating!
Gravock
