Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
gravityblock
Quote from: tinman on July 19, 2014, 03:57:17 AM
I said nothing about flipping the poles of a the magnet. I said ,Quote: We can place the wire in the north region,and the magnet will spin in one direction. We can place the wire in the south region,and the magnet will still rotate in the same direction-And this is correct thank you.Please read post correctly ,before saying some one is incorrect.
No, you are once again wrong!  The conductive magnet will spin in opposite directions when placing the wire in the north region as compared to placing the wire in the south region!
Like I said, prove me wrong, and I won't make another post to this forum!
Gravock
TheoriaApophasis
Quote from: d3x0r on July 20, 2014, 11:57:47 PM
Although I do wonder if being a hollow pipe defeated the electromagnet... much like a magnet with a hole in the center has an opposite pole in the hole.
NO, and no and no and no to that one. ..........And, NO.
There is no "opposite pole" in the "middle",  THERE IS the dielectric inertial plane around the CIRCUMFERENCE of ALL magnets.
You cut a magnet a 1000000 times, it will still be there, it is "incommensurable".  As it is necessitated to be so.
If a spherical magnet is put on a metal plate, it will balance so there's a north/south parallel to the surface of the plate, making the strongest binding... the flat rubber magnetic sheets used for truck decals and refigerator magnets have lots of north/south lines in them, which gives them the strongest binding force, and provides most stability in the weak material by actually having a south inbetween each north... the thickness of the sheet determines how wide these are...
If a SPHERE MAGNET is placed ON A MAGNET is has a PRECISE angle, due to gyromagnetic precession.    Its IN the book.
The south is felt most within the top/bottom boundary of the magnet, which in a fluid it will definately experience.... moving a magnet outside of this region will make it seem as if it's an all-north face, but with a thinner outer boundary and smaller sensing magnet, there is a flip outside of the material of the magnet (above)
NOPE to that as well.
TheoriaApophasis
Quote from: gravityblock on July 21, 2014, 12:27:30 AM
Maybe you'll take what I say seriously when you see the electromagnet wrapped completely and tightly in aluminium foil start rotating like the conductive nickel coated neo magnet.
Gravock
Once again (for the 4th time) son,  ROTATION/ SPIN  is NOT conjugate field reciprocation.
I suspect you are drunk or insane.
TheoriaApophasis
Quote from: gravityblock on July 21, 2014, 12:35:27 AM
Gravock
Demented child...........  EACH "side" OF EVERY MAGNET ON EARTH HAS TWO vortex movements,  ONE centrifugal, and ONE centripetal
So, every 360 degrees of a single cycle of the turn of a magnet you have:
2 Ether-field modalities: dielectricity and magnetism (of course).
6 total pressure domain fluctuations, 2 centripetal, 2 centrifugal, and 2 dielectric
10 field-boundary gradients
Which side is moving which direction?!!!
N pole is moving centrifugally CW and centripetally CCW
S pole is moving centrifugally CCW, and centripetally CW
back to school with you.
TheoriaApophasis
Quote from: tinman on July 20, 2014, 11:57:26 PM
Brad
If you want, I will put your credit and a couple pictures in the 3rd edition and give you credit for your new invention
IF you want,  As I said, I got many hundreds of 1000s of downloads on the book already     (NO I DONT MAKE A CENT OFF IT).
IF you want your picture and a credit for your discovery in the book, I will give it, if not, I wont put it there.      YOUR CHOICE.
Otherwise I will replicate same experiment and give you credit but use MY picture
