Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 17 Guests are viewing this topic.
gravityblock
Quote from: TheoriaApophasis on July 22, 2014, 05:51:57 AM
U missed the most important PART, he has the RIM EDGE TAPED OFF!!!!!!!!!!!!!!!     ;D ;D
see pic below
Yes, and the more you tape of the face of the magnet, the further the reduction of the vortex will be and the slower the rotation of the PM itself will be.  In a HPG,  place one probe at the axis and one probe at the rim.  As you move the probe from the rim towards the axis there will be a reduction in the voltage as you approach the axis.  There will be no voltage when both probes are at the axis.  The greatest potential is between the axis and at the center point of the two poles.
Gravock
TheoriaApophasis
Quote from: gravityblock on July 22, 2014, 05:57:24 AM
Gravock
HE DIDNT TAPE OF ANY PART OF THE CENTER POINT OF THE CENTRIPETAL/   CHARGE 'portal'.
WRONG SON,  charge enters centripetally  (DEAD CENTER OF BOTH 'POLES')................,   NOT CENTRIFUGALLY,     Ive said that 4 times already.
more disruption of the hydrogen bubbles? YES..........LESS ROTATION?????????    >>>>>>    NO  <<<<<
Son, the CHARGE is rotating the magnet!!!!!!!!!!    Not the hydrogen bubbles    ROFL !!!!!!!!!  Hahahhaahahahahahahhaha  !!!!!!!!!!!!   ;D  ;D  ;D
PATHETIC !!!!!!! OMG
And, his rotation is only a tad slower because:
A:  it has electrical tape on it with MORE DRAG than the slick nickel coating
B: he created greater MASS to rotate around the side of the magnet, ALL AROUND IT with several grams of electrical tape.
BOTH THOSE reasons are why its spinning a wee bit slower!!!
back to the books with you.
Thats why my 1000$  Bicycle wheels (the wheels ONLY) are SO LIGHTWEIGHT around the rim........LESS WEIGHT = MORE /EASIER TO SPIN
gravityblock
Quote from: TheoriaApophasis on July 22, 2014, 06:01:32 AM
more disruption of the hydrogen bubbles? YES..........LESS ROTATION? ??? ??? ??    >>>>>>    NO  <<<<<
And, his rotation is only a tad slower because it has electrical tape on it with MORE DRAG than the slick nickel coating
AND he created greater MASS to rotate around the side of the magnet, ALL AROUND IT with several grams of electrical tape.
Wrong, charge can enter either centripetally or centrifugally depending on the polarity of the current.  Centripetally will enter dead center at both poles.  Centrifugally will enter at the axis on the face of the magnet.  You will either have a negative voltage reading or a positive voltage reading depending on the polarity (centripetal or centrifugal) of the current.
Gravock
TheoriaApophasis
Quote from: gravityblock on July 22, 2014, 06:07:00 AM
Wrong, charge can enter either centripetally or centrifugally depending on the polarity of the current.  You will either have a negative voltage reading or a positive voltage reading depending on the polarity of the current.
Gravock
You demented fool,    NICE BS CLAIM   (I repeat CLAIM).    However its 100% dead WRONG.
ALL charge enters centripetally...........youre confusing  CW with CCW  (which pertains to BOTH centripetal AND centrifugal).
Centripetal is called CONVERGENT for a goddamn reason............ its the point of CHARGE.
Centrifugal is called DIVERGENT for a reason, is the point at which magnetism ALWAYS, ALWAYS, ALLLLWAYS  leaves a magnet.
regardless of which side,
regardless of charge or not.
gravityblock
Quote from: TheoriaApophasis on July 22, 2014, 06:09:11 AM
If this is the case, then reversing the polarity of the current wouldn't reverse the direction of rotation.  However, this isn't the case, because there will be a reversal in rotation with a reversal in the polarity of the current.  This isn't a claim.  What I am saying is observed in countless experiments.
Gravock
