Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: d3x0r on July 27, 2014, 11:45:24 AM
re: Theoria Apophasis part 20
SirZerp Channel list kinda...  He did lots of playing with a ferrocell too; but had 2 color LEDs... alternating color LEDs
https://www.youtube.com/watch?v=aitgJpy3FWo&list=UUSR-vy_Ue0raYCGMwtw4uqg
Really This seems to be dependant on the direction of the lights... since they're arranges as point sources pointed inward, you get a constant reflection equidistant from each LED... and each being offset forms a separate arc.  Would be interesting to see a row of Linear lights, and maybe 2   X/Y or 3 - a equidistant triangle instead of a circle.
Ohhhhh, I know all about him and his youtube vids and hes a great critter / person.      ;D ;)
Yes, I have COLORED LEDS,  currently Im using only WHITE LIGHT ringed LEDS.
I just got done building one and putting it together
There are other tricks too, mirrors, and using a black paper between, and other things I will make videos on.
At steep angles, you can see the centrifugal in 3D.......etc.
tinman
Quote from: picowatt on July 27, 2014, 12:31:40 PM
Tinman,
This video appears to be in agreement with the right hand rule.
Using the right hand rule, one would expect the rotation observed on the ID to be opposite to that observed on the OD.
The absolute directions observed for both ID and OD are a bit puzzling.  Most likely this is because we are dealing with ion flow as opposed to electron flow.
However, it may be helpful/interesting if you could verify that any flow or motion of the liquid itself is in the same direction as the bubbles in the immediate vicinity of the magnet.  Rather than pollute your tank with ink or dye, you might try making a wand using small diameter wooden or plastic dowel with a thread attached to the end.  The thread will act as a small flag and by placing it in various locations, you can map out any flow/direction of the electrolyte.
PW
Hi PW.
Could you take the time,and draw a sketch showing how the right hand rule would be in my video setup,using the polarities i have used.Also,if an ion flow is the cause,then why the different direction,even though both magnetic and electrical polarities are the same in each test.
Brad
Ken:
QuoteNo, you wanna play games and engage in Sophistry
No I don't.  My nature is to ask a straight question and expect a straight answer.
How can you "listen" to the small magnet changing polarity?
Why is there a black region on the monitor?
If you can't answer those straightforward questions with straightforward answers that make sense that people can understand then the logical conclusion is that you are being evasive because you don't know the answers.  If you don't know the answers then your claims about studying magnetism are a sham because you should know the answers.  If you can't answer some basic straightforward questions why should we give credence to your other claims?
It's a refreshing difference from your thread on the Energetic Forum, isn't it?  People here are challenging you to establish credibility and back up your claims as opposed to just blindly agreeing with you and congratulating you like sheep.
picowatt
Quote from: tinman on July 27, 2014, 05:02:40 PM
Hi PW.
Brad
Tinman,
Take a look at this wiki, about half way down the page to "Direction of Force"
http://en.wikipedia.org/wiki/Magnetic_field
If you apply the rule as given, you will indeed see that it predicts opposite spins on the OD versus ID.  However, it appears to me that both directions are reversed from what the rule would indicate.
You had the south pole up in those tests, correct? (and your compass still point north correctly?  We have seen compasses ruined from being around magnets.  Just asking...)
If you would, please confirm that the fluid motion is in the same direction as the bubbles using the "flag" idea mentioned.
PW
ADDED:  You need not bother to video the flag test.  If you say the fluid is indeed moving in concert with the bubbles, that's good enough for me.  But, make sure to check the flow right at the edge of the magnet where H2 is being generated.
TheoriaApophasis
Quote from: MileHigh on July 27, 2014, 05:12:18 PM
What on earth makes you THINK I want any CRED from you ( or anyone for that matter)?          How hubristic!!!
Ive got results, new inventions, and far more.     You have your flapping gums.
Only fools try to convince others of things they know is correct and prove,    only supreme fools try to convince sophistic skeptics of anything.
Your skepticism alone, and continued rebuke is EXACTLY what I want.
I would only question myself as being wholly WRONG, if I actually said something people like you AGREED with.   ;D  ;D
I havent seen this much sophistry, logomachy, and pseudo-intellectual loaded questions since I was debating the translation of the Sutta Nipata with Thera B. Bodhi
;D ;D
"You never change things by fighting the existing reality. To change something, build a new model that makes the existing model obsolete."  ― Richard Buckminster Fuller
Quantum Qwackery, your Particle-Mysticism is a lie perpetuated by academia.    Its nothing but Greek Atomism.
I will answer ALL YOUR QUESTIONS,.........soon as you define  ONE WORD:             FIELD     LoL  ;D  ;D
Go invent something and have a cookie.    Better yet, go write a book 'proving' mine is wrong.  ROFL
