Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
93RDELEMENT
There is a vortex ! But first the so called qualified statement !All science is progressive ! Second I have a zero point magnetic field vortex, AND ITS NOT IN A BOOK OR UNIVERSITY ... Please don't question peoples descriptions and involve personal petty politics, if the picture does not fit your frame of reference try to look at how others see things you will be surprised what you will learn that is not in the book .... Also it is obvious that there is a level of intuition one is being drawn to a new perspective and that one will need to keep looking but he is close ...
If you all keep getting stuck with a limited old fashioned and out of date system of knowledge than let go and open to the new world of quantum reality and any half backed quantum mechanic will agree that anything is possible at any time ... Try and work out how miracles work as a physical system ! Also cause and reaction may not always lead to a logical answer ! I have seen objects materialise and dematerialise something to do with a ghost or I call it the ghost field and it always starts with a magnetic vortex ...
To pigeon hole the dielectric effect with a magnet and not include gravity is a big error ! Some systems will not work in zero gravity like a bucket of water with a hole in it, find the connection to gravity than you will think again ... I like the opening of this thread its got no personal gain to it and is openly honest with its view but needs my magnetic vortex to help it along ! Do you have one ????? NO !
My question to all is what is the connection between a magnet the dielectric effect and gravity, don't bother with Maxwell's equations he never new that a graviton was possible let alone a neutrino that can travel above light speed ! So lets just look closer at a magnetic vortex, that to me is an oscillating  magnetic field without a spinning magnet, just the field will do for now so hold the magnet down .....
When AND IF you are ready I will give you a one directional magnetic flow of force without the magnetic spinning !!! CAN YOU DO THAT ???? ITS NOT IN A BOOK, ITS IN MY LAB ..... Also I will teach you how to set up a magnetic vortex using the earths magnetic field  but if you don't have any ferrite magnets forget it, neo is just to dam tight so you need to loosen up the field hahahah a bit like your personal petty politics ..
Lets start again and help up date the book with the real macoy !!!!!!!!!!!!! But no doubt you are all so entrenched in your books and out of date academic studies that you are to dam frightened to go that one steep further and finally become free from the rot ... MAGNETIC VORTEX IS GO !!! COUNTDOWN TO LAUNCH HAS STARTED OOOOPS THAT MEANS A FLYING MAGNET, OH SORRY THATS A BIT TO MUCH FOR YOU AT THIS POINT HAHAHAHAH .......
Yours truly
king monkey and the 93rd element ! lol xxxxxxxxxxxxxxxxxxxxxxxx
TheoriaApophasis
Quote from: 93RDELEMENT on July 27, 2014, 05:58:40 PM
There is a vortex !
You are the same teenager that sent me a private message stating you "were MUCH MORE intelligent than Tesla, Steinmetz, Maxwell AND Heaviside"
Yeah, you go with that.
Ken:
Okay, so you are admitting that you can't answer those two basic questions to demonstrate to the readers that you possess a basic competency in magnetism.  So this whole "Realm of Theoria and his Big Fish Story" is all just a classic "big splash" onto the "scene" with no substance at all.
There used to be a thread on the Energetic Forum called "Free Energy at Last - Step by Step, Must See."  It was a project by "Imhotep" and all it was was rewiring a computer fan motor into a pulse motor.  Nothing to do with free energy, NADA.  When I asked him some questions all that I got was some blank stares.  Imhotep was clueless, all that he did was show how to rewire a computer fan motor - no free energy in sight.  Then he faded away because he had nothing more to offer.  But he got a big following, that's for sure.  A big following left holding an empty bag.  I predict something similar will happen with you.
Back to the old, "What is a field?" argument I see.  That is pure sophistry on your part, and the pot calling the kettle black.  You are trying to hide and change the subject, but you can't hide.  People are reading this thread and there is nowhere for you to go.
QUESTION:  How can you "listen" to the magnet changing polarity?
ANSWER:  You wrap a coil around the axis of the magnet.  When individual magnetic domains flip you will get a small amount of EMF generated in the coil because of the net change in magnetic flux with respect to time.  Each magnetic domain flipping will create a "tick" and when lots of domains flip at the same time you should get a sound similar to a Geiger counter.  So you connect the output of the coil to an amplifier and connect the amplifier output to a speaker.
QUESTION:  Why do you see a circular black void when the magnet is close to the CRT monitor?
ANSWER:  For certain positions of the electron beam, it is cutting across strong lines of the magnetic field from the magnet.  That causes the electron beam to take a spiral path.  When the field is strong enough and the geometry between the toroidal magnetic field from the magnet and the electron beam is just right, the electron beam will spiral around and end up striking the phosphor several inches away from where it would normally strike the phosphor.  The net result from this is that the magnet can create a void on the monitor because the electron beam that was supposed to strike the void was induced to spiral away and strike somewhere else because of the strong Lorentz forces at play.
So, you see that, Kenny?  Two basic basic questions about magnetism that you were unable to answer.  Don't go crying in the corner or try making your feeble "fields" play.
You do not understand the basic fundamentals of magnetism because you are unable to answer some simple questions about magnetism.  Kenny the emperor-wannabe has no clothes.
MH, you are far too easy on Terrible Apoptosis. Anyone can spout gobbledegook and make it sound "consistent" with the rest of his gobbledegook. And it's clear to everyone that he isn't going to answer your simple questions... because he cannot.
But why not ask him something really _hard_, something that any first-year, indoctrinated, hidebound EE student can do in the lab in a few minutes: Design and build a simple oscillator, showing a calculation of operating frequency, then build it out and show by testing that it does oscillate at the design frequency. The EE student will of course use QED and ordinary mathematics and will arrive at a device that does "what it says on the tin" with minimal components and almost no flailing about calling it "experimentation". The ordinary formulae which depend fully on Maxwell being RIGHT will tell the student which components to select and how they will behave. Apoptosis, though, is constrained: He cannot use any of the information from the "theories" like QED with which he does not agree. Nor can he use the math derived from that. Maxwell is FOS, so he's out too. Tick tock, the lab period is almost over and our Tattooed Genius is still drawing spirals on paper. Where is his oscillator and the math to support its design?
Can you imagine, MH, trying to work with someone like Theoretical Apoptosis, in order to design and build something like the MHOP?  He'd still be telling you that everything you know is wrong and that it can't work unless you can define "FIELD" on a big green patch of grass. I am laughing in my evening coffee now.
Quote from: MileHigh on July 27, 2014, 06:27:32 PM
Ken:
But even more important than the Barkhausen phenomenon itself, is that it is PREDICTED and its parameters can be CALCULATED according to conventional QED.
Again, conventional electronics engineering science can not only design the CRT in the first place but PREDICT exactly how it will behave under a wide range of conditions. It can even precisely _calculate_ just where those deflected beams will actually land, predict the Dark Zone to tell you precisely how big and what outline it will have, for different applications of the external field. Note this well: It matters NOT if you can come up with some definition of what a "field" actually IS (it is a map) as long as your understanding of its _characteristics_ is good enough to allow you to _engineer_ with it. Conventional QED does impart that ability. The nonsense Apoptosis spouts does not.
