Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
TheoriaApophasis
Quote from: Pirate88179 on March 03, 2015, 09:08:48 PM
You must have meant erroneous evidence right?
indeed i do, refer your LAZY WORTHLESS Gdamn ass to the past 100 pages.
Might i remind your FUCKING ASS, (your dumb ass), that a Hypotrochoid CANNOT even be DRAWN or created outside of the mechanics of a vortex
(but maybe your dumb ass doesnt know what a hypotrochoid is).
you and the OTHER COCKROACHES think the term VORTEX is some MAGIC thing like a Unicorn , or some such BS,  its not  ;D ;D ;D
copyright 1.14-2015  Ken l W.
A vortex is a compounded or compounding spatial force vector expression within which or by which magnetic-force vectors are expressed against its/their originating counterspatial dielectric locus (inertia) along a curvilinear force-and-inertia pressure mediation as against the counterspatial locus of said divergent curvilinear expression. Compounded macrocosmic natural phenomena vortex (fluid, environmental) events are void or vacuum convergences against a pressure stasis. Cosmic vortex phenomena are left for another discussion, however are likewise akin to magnetic hypotrochoid expressions. As per magnetic vortex hyperboloids, force and space-creation are torsional ('inertial-friction') along golden ratio extrapolations and are additive, whereas convergences are dielectrically multiplicative. This is expressed as space is additive and synonymous with magnetic divergence, whereas counterspace is multiplicative. A magnetic vortex is a dielectric projection of force vectors, which follows a hyperboloid.
A vortex, in simple, is merely a curvilinear expression of force-against-dielectric-inertia reciprocation whereby which no straight lines exist in the universe, in that all force vectors are 'tethered' at a counterspatial locus within which and by which any and all divergences are torsional convergences as against a necessitated polarized locus (micro [atomic], or macro [magnet, a coherent mass]) which exists against all space by definition. The hyperboloid is the curvilinear expression of the loss of inertia which is extrapolated as a 3D hypotrochoid, or spatial torus. All geometry is projective geometry; likewise the magnetic hyperboloid is an inertia-and-loss-of-inertia phenomenon by which pressure reciprocation necessitates spheroidal convergence by means of hypotrochoid reciprocation. Negative pressure dynamics mediate pressure force reciprocations towards inverse counterspatial sink. The magnetic hypotrochoid is a convergence by means of polarized divergence vortex by nature, however the center of any and all torus formations, is the hyperboloid. The counterspatial 'center' of the torus is dielectric inertia, or counterspace from which the magnetic vortex, or torus is expressed necessitatively.
Even a centrifugal vortex is centripetal, in that it MUST reciprocate the geometry of the hyperboloid to converge centripetally at the opposite spatial displacement of centripetal convergence ("opposite pole"). There are no straight lines in the universe, all force vectors are curvilinear and move along a spiral around one or more counterspatial "tether-points". Contrary to the pontifications of pseudo-science, there exists NO open vortex phenomena in the universe, all force vectors are CLOSED.
Ultimately a vacuum created vortex (water vortex, water down the drain) or a magnetic vortex are both expressions of counterspace, one a localized void, the other an Ether-convergence. No force ends in space, because space is NOT a receptacle for force, rather the posterior attribute of divergences. All force vectors terminate at the origins, in inertia, or as meant counterspace.
Coherent magnetic reciprocation expressed by a magnet's (polarization collective with coherency) divergence exists as a pressure-force hyperboloid as necessitated by the dielectric counterspatial locus so-deemed by modern inept and defunct physics as a "Bloch wall".  Inertia is the counterspatial 'tether point' at which and by which all force vectors, magnetic and otherwise express curvilinear reciprocations as defined by the space they create in so doing.
The absolute inverse of inertia is nothing, which is space. Space is neither a FIELD nor a FORCE, and has no properties, is it is purely a posterior attribute of the force reciprocations of magnetism. Force is nothing whatsoever, and the expression which gives definition to all phenomena in the universe.
"Under" the spheroidal field (really a force, not a field, only dielectric is the true field, magnetism is purely a force only) of magnetism, either atomic or the magnetic (coherent single mass) exists the spatial-counterspatial HYPERBOLOID, failure to understand this will make your compression of what the term "polarization" both IS and IMPLIES in the definition of what both magnetism IS and is meant, and how this applies to the magnet itself.
sarkeizen
Quote from: orbut 3000 on March 03, 2015, 08:46:25 PM
The magnetic vortex. Is there proof that such thing exists?
I can help you figure that out...here's a quote:
"My gaping asshole is the power to move which is extended from the mind of the creator to create thought wave bodies in the image forms of the creators imaginings" - Walter Russell
Now if someone approached you and said that. Would you think the person is right or wrong.  If the former then probably mountains of evidence exist from that perspective if the later then you can count yourself among the sane folk.
orbut 3000
Quote from: sarkeizen on March 03, 2015, 09:15:24 PM
Huh?
© 2015 orbut 3000
sarkeizen
Quote from: orbut 3000 on March 03, 2015, 09:23:06 PM
Huh?
See those are (pretty much) the words of Walter Russell the man-god that ApotheosisOfCray is on about.  If you think the quote is verbal diarrhea (no pun intented) then his work (especially his early work) isn't much different.
sadang
Just a matter of interpretation and education! For the record!
- https://archive.org/stream/WalterRussellTheSecretOfLight/WalterRussell_TheSecretOfLight#page/n0/mode/1up
