Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 76 Guests are viewing this topic.
John.K1
Quote from: Atommix93rdAtom1 on January 23, 2016, 11:37:19 AM
joel321
But you only need one book and its called the cosmological principle ......... Start ASAP go and get this book from the library and confirm you have it ..................................
I have all episodes of Stargate Atlantis. It is handy too.  :D :D :D
CycleGuy
Quote from: Dog-One on January 22, 2016, 06:35:24 PM
No picture of the box says a lot.
He'll keep talking and BS'ing until one or more of the more gullible members of the forum sends him money... but he'll never demonstrate any of his fantastical and provably impossible devices... because they don't exist. He's no "master of the quantum", he's merely a master of bamboozling weak-minded gullible fools into thinking he is so they'll send him money.
I invite everyone to cordon off those who would subscribe to these odd hobby theories so the forum can get down to the work of producing a working OU device that's in full accordance with QM. It can be done. We're not in a "closed system", everything in the universe freely exchanges energy with the QVZPE field... so the old "you can't 'create' energy from nowhere" doesn't apply... we're not creating it, we're tapping into it. And given the double-loop strange attractor nature of magnets, utilizing magnets to do so seems to me to be the easiest route.
Haisch and Moddel have one means by which it can be done, utilizing a Casimir cavity to artificially lower QVZPE field density, thereby causing the electron orbitals of a noble gas to drop in their orbits (the QVZPE field being the underlying cause for electron orbitals not going below their 1s orbits and 'crashing into' the nucleal protons, after all), giving off photons that are then converted to electricity or heat. After the noble gas exits the Casimir cavity, the electrons gain energy from the QVZPE field to return to their normal orbits. This can also be done with magnets stressing the QVZPE field density to lower it, but the magnets would need to be incredibly strong. Unfortunately, the Haisch and Moddel method can only extract minute amounts of energy because Casimir cavities are tiny by their very nature.
I conceived of a second method, but I'm unsure if it'd work... there's nothing I can find in QM or QED that prevents it from working. I simply don't have the time or energy right now to do the experimentation to confirm or null it. It has to do with subdividing the quadravortexual nature of magnetic flux.
We can all agree that magnetic flux is mediated by Larmor radiation in the form of virtual photons, that's a basic precept of QM. The angular acceleration of the electrons in orbit about their nuclei in a magnet, and electron spin, necessitates that they give off Larmor radiation. This energy output is balanced by their taking in energy from the QVZPE field, which is what prevents electrons from going below their 1s orbital. Thus, the QVZPE field underpins the stability of all matter. All matter exhibits this behavior, but in a magnet, the coherency of the Larmor radiation manifests in what we perceive as a magnetic field.
Because our relatively weak magnetic material cannot withstand the internal magnetic stress, some of the domains unpin and flip, thus interspersed throughout a conventional magnet are actually two magnets of opposing spin. This is why you can cut a magnet and have a N and S pole in each cut piece. It's also the reason why the Bloch Wall region can move to again minimize the internal energy of a magnet when it's cut.
A magnet thus has two 'interfaces' on each pole face, an Attractive interface which draws virtual photons in from the QVZPE field, and a Repulsive interface which throws virtual photons off whereupon they're subsumed back into the QVZPE field. The centripetal of one pole face and the centrifugal of the opposite pole face constitute one path through the magnet, and the opposite centripetal and centrifugal constitute the second path. The two paths loop between each other endlessly, out of Path 1's centrifugal, into the QVZPE field, out of the QVZPE field, into Path 2's centripetal, out of Path 2's centrifugal, into the QVZPE field, out of the QVZPE field, into Path 1's centripetal, out of Path 1's centrifugal, etc., etc.....
Due to the nature of centrifugal and centripetal vortexes, the centripetal will always spiral inward on itself, thus it is concentrated at the center of the pole face, whereas the centrifugal vortex always spirals outward, and thus it is concentrated at the perimeter of the pole face.
See my images in a prior post for a graphical explanation.
Since magnets directly stress QVZPE field density, and the QVZPE field quite literally is the fabric of space-time, magnets exhibit temporal effects known as time asymmetry. The centripetal interface on each pole face speeds up time, the centrifugal slows down time.
In a conventional electrical generator, we're playing with three effects... the centripetal interface speeds time up, the centrifugal interface slows time down, and the rotation of the generator slows time down. The centripetal interface speeding time up counteracts the centrifugal interface slowing time down, which is why we need to utilize rotation to cause a compression of space-time, and thus a perceived charge compression in the wires of the generator, and thus that charge gets pushed out over the wire to power loads.
But if we were able to separate out the centrifugal and centripetal interface fluxes and reroute them so they were both going in the same direction rather than counteracting each other, we wouldn't need rotation to generate electricity.
[EDIT]
Ah, so what I learned today:
They're not referred to as centripetal and centrifugal vortexes, they're referred to as 'vortex' and 'anti-vortex'. In the parlance of perturbations of the QVZPE field, the vortex and anti-vortex are opposites and mutually annihilate. The vortex would be what I was referring to as the centripetal interface, the anti-vortex would be the centrifugal. A magnet is a dual vortex and a dual anti-vortex (one vortex and anti-vortex on each pole face) frozen into a molecular matrix that sets up the two perpetual virtual photon flux paths through the magnet.
[/EDIT]
sadang
For those who still want to shape the reality according to their own understanding and will, and not to the others:
- https://www.youtube.com/watch?v=3ygw-t7ncJU
AlienGrey
I tried years and years ago to bend light with a realy strong magnet, and with a laser guess what it doesn't work, the only way i know is to use hard ware and scan it that way.
Also Aluminum is magnetic, just lower it's temp ;)
So then where in the video does he bend light ?
AlienGrey
Quote from: Atommix93rdAtom1 on January 23, 2016, 07:11:41 PM
Mr gray !
Its just refraction in a lenses ! He also claims every thing is just inertia including gravity but gravity can cause a planets core to heat up and I don't see inertia doing that ..
We are ready for you to come on board when your ready ect ........... The nda will also have a joint ownership deal ect !!! There is a solid plan we are working to and we do know what we are doing .
Yes i know how that works.
Mr Atom hello, I don't want to appear un grateful to your kind offer but I sent you a quick none disclosure agreement by e-mail, please send me some thing back to show that you are up front and it's real, I'm naturally a wary person about these sort of things as you are giving nothing away about your personal  self or the project.
Waiting your reply
With all due respect regards Alien Gray
