Thanks to ALL for your help!!
multiplying electricity
Started by that_prophet, July 19, 2014, 05:54:04 PM
that_prophet
Quote from: webby1 on May 11, 2015, 08:44:16 AM
I have never had this arrangement work,,I have built and tested a few variations,, it is an interesting idea but not a working one.
Your input motor can only pull on the string\chain\belt with so much tension,, anything that uses that takes away tension for the other parts to use,, it is that simple.
If you do not understand that then YOU must build your own testbed,, you can see the drop in force by using a rubber band and a bunch of pulleys,, where you put some resistance to rotation is where you will see the rubber band stretch and shrink,, BTDT.
"I have never had this arrangement work" THAT IS BECAUSE YOU NEVER USED SIMPLE MULTIPLICATION BY VARYING SIZES + USING ADDITIONAL PULLEYS
This MUST WORK, it uses such simplistic techniques, 100 to 1 multiplication of varying sized pulleys, simply has to work. You are only putting in the DC electricity to rotate you large 100cm pulley one complete time, which is only a spark of current. A belt, strap, rope or string connects one to ten mini-pulleys, causing them to rotate 100 times for each mini-pulley that is attached. 10 X 100 rotations = 1000 units of AC electricity. Now remember that we only need a spark of current to rotate the DC drive motor one single time. What we need is only a spark, and we should be able to easily get one gigantic spark from the combination of the 1000 units(sparks), of AC electricity.
that_prophet
there is no torque problem,
electric motors rotate extremely easy
Free Energy http://free-energy.yolasite.com/
is so ridiculously simple, that I hope it will shame you into doing something about the evil influence in our society that is deceiving our children, (http://decimationofthisevolutionfairytale.yolasite.com/ ). You only have to put a spark of DC electricity into this system, while it can return 1000's of units of AC electricity. You do this by connecting a 1000cm circumference pulley to a DC motor, attach a belt to this pulley, and then run this belt through ten one centimetre circumference pulleys. Then you rotate this large pulley by hand, only one time. This would only take a spark of DC electricity, as you are only rotating it the once. This spark of DC electricity, one rotation of the motor, will give you a return of 10,000 units of AC electricity. Now, try and tell me that this 10,000 units of AC electricity does not have the voltage,(electrical pressure) to have the torque to rotate your DC motor one single time.
Pirate88179
Quote from: that_prophet on May 17, 2015, 06:49:16 PM
Free Energy is so ridiculously simple, that I hope it will shame you into doing something about the evil influence in our society that is deceiving our children, (http://decimationofthisevolutionfairytale.yolasite.com/ ). You only have to put a spark of DC electricity into this system, while it can return 1000's of units of AC electricity. You do this by connecting a 1000cm pulley to a DC motor, attach a belt to this pulley, and then run this belt through ten one centimetre pulleys. Then you rotate this large pulley by hand, only one time. This would only take a spark of DC electricity, as you are only rotating it the once. This spark of DC electricity, one rotation of the motor, will give you a return of 10,000 units of AC electricity. Now, try and tell me that this 10,000 units of AC electricity does not have the voltage,(electrical pressure) to have the torque to rotate your DC motor one single time.
Your spamming of multiple topics with the same thing has been reported to the Administrator of this website.
Bill
citfta
that_prophet
Quote from: citfta on October 16, 2016, 04:55:27 PM
Your device is useless!
THANK YOU,,, for using such specific points, to help direct me, to just exactly where my logic is going wrong
free energy is done using pulleys
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
If you attach AC generators to each of these 1cm mini-pulleys,
you would gain 100 units of AC electricity, for every 1cm pulley that you attach.
This could be massive amounts of free AC electricity,
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
