Overunity Magnetic cone drive!!
Started by vineet_kiran, July 30, 2014, 05:43:28 AM
vineet_kiran
Torque / Power magnification using permanent magnets.
tinman
And this increases torque how?
If there is no slip of the magnetic coupling,the motor and generator are still a 1 to 1 ratio.
MarkE
Vineet, unless you really enjoy getting shot down out of the gate, maybe you should perform some basic analysis on these ideas of yours before presenting them.
vineet_kiran
Quote from: tinman on July 30, 2014, 06:03:10 AM
Torque = Force  X  Radius
WIth every step of magnets as shown in the figure, radius goes up hence torque goes up.
Since magnets  are provided at the end of radius,  force acts at the end.  Hence you get magnified torque at the center. I think for same reason we use spanners, wrenches, handcranks etc.,  to get magnified torque at the center.
Power = 2π X RPM(N) X Torque
RPM (N)  remains same for both motor and generator. Hence when torque gets magnified, you get more output
from the generator.
Quote from: MarkE on July 30, 2014, 06:09:17 AM
I don't think anybody will enjoy shooting me down at gate because it will be a mere waste of bullet.  Quality bullets are expensive
nowadays.  Using butcher's axe would be a cheaper method.
Anyway if it is wrong,  tell me why it is wrong.
tinman
It's wrong because your holding your wrench around the part that is around the nut,and not the outer edge of the wrench.Simple mechanics can explain why this is a no win situation. Insted of spending a lot of time and money on magnets,bearings,and all those fancy free spining arms,simply replace your magnet cone array with a steel or plastic funnel. You have exactly the same thing-small radius at the motor,and large radius at the generator.
You see,you forgot one thing,and that is you have to have a disk from the generator shaft(small radius),to the magnetic cone's large radius. So if we look at it from your angle,you geared down,and now you have to gear back up to conect it to the generator. Might aswell just use a yanki coupling to conect motor to generator,and be happy with the 75% efficiency.
