Oscillating sine wave LC tank magnet motor.
Started by synchro1, August 31, 2014, 09:26:50 AM
MarkE
Quote from: synchro1 on September 04, 2014, 07:12:13 PM
@TinselKoala,
Because you're BULLSHIT! Stay off my thread!
Synchro1: Fair is fair.  When you referenced TK's work you opened yourself to TK's comments, especially when he disputes your representations of his work.
synchro1
@MarkE,
TK is an egocentric sadist. I am unwilling to stand for his abuse. He denied the existence of the "Negative Mico Henry" and  "Magnetic Resonance", he also preaches "Atheism!" He portrays me as a fraud. He's challenging us to supply material proof of a Creator, in denial of everything sacred in the Universe. Who wants to be preached to about Holiness from a shabby "Row House Basement"?
Wiring a  0 to 10 pico farad variable trimmer capacitor to the series bifilar would not only eliminate the need for a "Super Cray" calculation for fixed bifilar tank capacitance, but set at zero, would allow for the ground only test. The only other possibility as I see it, would be to investigate the possibility of a Reed Switch oscillation type fluttering. Most of those switches are crap and wind up sticking right off the bat.
MarkE
Quote from: synchro1 on September 05, 2014, 10:03:51 AM
@MarkE,
There are two problems:  It is a public message forum.  Unless someone is so abusive that Stefan deems it necessary to intervene, people get to express their opinions.  Second:  It should be common sense that if one cites somebody else' work, they have invited that other person's comments.  If you want to discourage TK making comments about your ideas, then inviting him by referencing his work is contrary to that goal.
Trimmer caps don't go to zero.  They can go to a low value.  If you want to shrink capacitance by orders of magnitude, then remove the capacitor, variable or fixed.
synchro1
@MarkE,
You have it backwards! I commented on a video he uploaded of a "Coil Core Magnet Spinner" he gave me credit for innovating. I was among the first builders to begin experimenting with this approach nearly nine years ago, and I believe the first person to succeed at building a "Sine Wave Harmonic Self Accelerator".
I believe that the spinner picked up on a third harmonic of fractional amplitude, and climbed the Harmonics in "Barkhausen Spikes" to the bifilar's self resonating frequency where it's speed stabilized.
Try lighting a D.C. filament bulb with a D.C. pulse at 180Kz. What an incredible display! The light is separated into standing waves that form a spherical magnetic field as if it were a planetary field. Truly Fantastic! This frequency is the "Oscillating Frequency of Magnetisem" and has nothing to do with ferrite characteristics. TinselKoala denies it exists!
synchro1
We're examining a very simple circuit of merely three components: "D.C. battery", "Reed Switch", and a "Series Bifilar Air Core Solenoid Coil".
There's three options to choose from: 1.- Zero external Capacitance.
                                                         2.- External capacitance of value.
                                                         3.-Switch Oscillation.
We covered the first two. The third, can be controlled by replacing the crappy Reed Switch with a CRYSTAL. We select a crystal that spontaneously self resonates at the self resonant frequency of the series biflar, and match the spinner R.P.M. , then blade switch the oscillating crystal into the circuit!
