Image compliments of Poynt99.
Look at the text and compare it to the image:
Before I enter the south end of the magnet I note that there is a magnetic field in a direction that starts from behind me and goes forward in the same direction I am moving in.  1/4 way through the magnet the magnetic field is the same and when I look all around me I see magnetic domains all oriented in the same direction as the magnetic field.  1/2 way through the magnet the magnetic field is still the same and when I look all around me I see magnetic domains all oriented in the same direction as the magnetic field. I look around and I do not see any Bloch wall showing a boundary layer between magnetic domains and their associated magnetic fields that are in a different direction.  3/4 way through the magnet the magnetic field is still the same and when I look all around me I see magnetic domains all oriented in the same direction as the magnetic field. When I emerge from the north end of the magnet I note the magnetic field is still the same; it is still in a direction that starts from behind me and goes forward in the same direction I am moving in.
https://www.youtube.com/watch?v=r38qMrjrSqs
In the above clip Chris Sykes thinks he is seeing Bloch walls with his magnetic viewing film.   The attached three images explain exactly what he is seeing, and it certainly is not a Bloch wall.
EMJunkie
Quote from: MileHigh on January 02, 2015, 07:13:13 PM
MileHigh,
Hard Scientific Data that is PEER Reviewed with many other experiments to back up the HARD DATA is ONLY REFUTED BY FOOLS! Lets not forget, PROFESSIONALS doing Professional Experiments! Especially when more simple experiments that are very easily replicated also prove the same HARD DATA!
You're using ideas and diagrams from a 100 year old concept! It is time you update your theories!
PEER REVIEWED: http://hamiltoninstitute.com/wp-content/uploads/2011/11/WIN_HAM-5.pdf
Don't embarrass Science and stop embarrassing yourself! Learn what's really real instead of what you read in out-dated, incorrect, text books!
With regrets and a saddened disrespect for Ignorance
Chris Sykes
tinman
Quote from: MileHigh on January 02, 2015, 06:28:44 PM
Before I enter the south end of the magnet I note that there is a magnetic field in a direction that starts from behind me and goes forward in the same direction I am moving in.  1/4 way through the magnet the magnetic field is the same and when I look all around me I see magnetic domains all oriented in the same direction as the magnetic field.  1/2 way through the magnet the magnetic field is still the same and when I look all around me I see magnetic domains all oriented in the same direction as the magnetic field. I look around and I do not see any Bloch wall showing a boundary layer between magnetic domains and their associated magnetic fields that are in a different direction.  3/4 way through the magnet the magnetic field is still the same and when I look all around me I see magnetic domains all oriented in the same direction as the magnetic field. When I emerge from the south end of the magnet I note the magnetic field is still the same; it is still in a direction that starts from behind me and goes forward in the same direction I am moving in.
OK ,im lost.
How or why dose the field turn around when you do,and exit where you entered?.
MarkE
Quote from: EMJunkie on January 02, 2015, 08:05:19 PM
MileHigh,
Chris Sykes
Christ, these people have confused magnitude for direction.  Optical illusion "leads out" massive delusion.
