Nuclear Resonat Battery test soon to come
Started by pomodoro, September 28, 2014, 08:06:59 AM
pomodoro
While working on equipment to test the avramenko plug accurately, I was lucky to come across 50 or so grams of uranium nitrate (Uranyl Nitrate).  Immediately I  (temporarily) dropped the project and decided to brush up on an old interest of mine (and thousands of others) - the Moray device. This is probably the device with the least BS associated with it.  Many of you know of the device, but for those who don't , there are two major ways, which this 50kW device apparently worked 1: It tapped into the 7Hz Schuman resonance or 2: It contained radioactive substances in the 'Moray valve' or tube. There is no doubt it oscillated, probaably in the kHz range. Other theories talk of the zero point energy, cosmic particles etc, but these are extremely unlikely.
Paul Brown in the 80's suggested that Moray used radioactive substances in the RF resonant circuit, and Brown apparently built a working device as shown in his patent. Brown was charged with fraud eventually, but it is believed that it may have been a conspiracy.  The Hubbard coil is another device that used radium to power a boat for hours.
My idea is to monitor a kV discharge from a capacitor into a high Q coil. In the coil will initially be air only, then salt  and finally uranium nitrate.  I would expect the one with the uranium to show less damping  of the oscillations than the others.
Any ideas, comments before I start please (technical only).
profitis
We have to get to the basics first.moray was playing with valves ie moray was definitely playing with thermionic emission of sorts.let us hypothesize from there
profitis
Radium or uranium inside a rectifiying cold cathode tube,what percentage of gammas can be auto-rectified in this way?
profitis
Morays own words from drawings: 'portions of germanium were used...Ge,FeS,MoS,Bi,uranium' sounds like gamma rectification for definite
