Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
pg46
Hi Ironhead-
I passed on the word to H2opower. He says he is unable to log onto overunity.com at all now from his home computer??? I will pass on any info I get from him if he is still having some challenges.
About your system - it's a pretty cool looking unit. How much gas does it produce anyways? Are you running a vehicle on HHO alone or as an addition to your gasoline system? How much did your cell plates cost? How much spacing do you have between the pates?
IronHead
I never really intended to publish this  so I have not done proper  gas volume test.
I test gas output by how well the engine runs and how much vaporized gasoline needs to be added.
So I have no numbers for you on this. This is all trial and error type work.
Thickness between plates id 1/8 inch .
The cost is very very high but soon to be lowered as the silver will be replaced with
Nitronic Stainless steel a very low iron content  stainless.
The tungsten alloy was around 200 $ from a local machine shop where I live.
The cell has run the engine alone but not a high throttle  and not as stable as it should be so vaporized gasoline is added.
The gasoline is first filtered through a coconut carbon filter then passed through 4 x 2 inch neodymium magnets .
Also some timing adjustments.
IronHead
Forgot to add that after gasoline goes through magnets it is heated  around 700F
pg46
Ironhead-
Sounds like you have an interesting system there. I am hoping you are happy with your present fuel consumption then?
I was curious - what does the coconut carbon filter do to your gasoline? or should I say - what is it that it is filterng out?
I am betting that you aren't far off from soon running on a water-only based system.
Best Of Luck,
h20power
Hi Everyone ;D, Well, my computer is nolonger able to get on this site. I don't know what they did to it, but it always says,"internet windows explorer can not open the site overunity.com." So, I have been blocked from my home pc's as to get on overunity.com :'(. For I can get on any where in the world but this site. I am at the college right now, for they can't kill all these computers ;). I gave some really big secerts in that big posting on page 6. Water for fuel is a reality, I like ironheads design, just need to put in one nutral coil to get the capacitor effect. Now in order to get vauums to do work just take a look at the vehicals vacuum brake assit drum. See how wide it is, this is needed to get the vacuum that the engine can produce to do work, that's why my unit is so wide @8.625" in diameter, 10-14 inches would do even better. Remember vacuum does two things for us; it lowers the energy of activation for the break down of water, this is the phase diagram of water electrolysis theory of mine, and pulls the water vapor pressure away, this is the hydronium theory of mine. The best place to hook up too an automobile's vacuum is the line going to the vacuum brake booster. This is the place where the vacuum is the best, and is why the brake booster is hook up to this exact spot. Now the units should also think of taking advantage of the paramagnetizim of oxygen, to do this you must bring the negetive to the device, the hose I use has steel in it that I can get too to do this easily. Just make sure to isolate it from the positive so you don't get a direct short. I use a rubber gasket and neoprine scews to do this. The math I gave can be used to determine the energy of activation of the water in your unquie envirenments that you created. For as long as the engine is running it will never go to 1 atm of pressure. Just find out how much vacuum your engine is pulling and put those numbers directly into the equations given. Make sure your in the same units and away you go :D. Hypower.com will be posting a video on Feb 28, 2007, of a VW GTI and some fords working on water alone, go to the site h2oforfuel.com to get a lot of good info on the use of water as a fuel. If anyone has any questions just e-mail me directly, I will try an answer them as best I can. For what I have put on for all to learn here is a way to be off of gasoline forever, Meyer's technology works! Note use bigger tubes minimum .626" in inside diameter, and don't forget to tie into the vacuum brake boost line. Zigarouas.racing will have a video out too in the very near future, and so will I ::). The hydrogen revolution has started what side are you going to be on? Siding with the oil & power genarating industries or with us ??? The time has come to take a stand, save yourself some money and clean up the air at the same time, that's it for now. God Bless and live well. Just me h20power........
