Magdrive HHO Generators
Started by ZeR888, September 12, 2006, 05:42:34 PM
pg46
Quick questions for H2Opower
Are you using any electrolytes?
Under a vacuum how do you protect from a backfire exploding the cell if you cannot use a water bubbler system?
h20power
Hi, I think this one will show up, I hope, had to re-render it. Your design is very nice, mines darn near bullit proof, plus a lot of maching went into the cell.
h20power
I don't worry about blow back, the cell is designed to withstand it. It's actually stronger than the engine with .322 inch walls made of 316 stainless. It's kind-of costly but very effective. I spent over $900 on this prototype, put over 70 hours in machining work, thank God I can do all the work myself :).
IronHead
Impressive design and machine work.
pese
weil es bekannt ist dass Autobatterien explodieren k?nnen , wenn man beim schnell-laden , mit feuer oder nur funken der elektrokabel spielt und dies nur auf den  erzeugten wasserstoff zur?ckf?hren kann , der bei zu starkem laden = ?ber 15 volt erzeugt wird .  Liegt es doch nur auf der Hand , dass man neue oder alte autobatterien auch zur HHO Produktion benutzen kann. (Wasser pur , Wasser mit S?ure , Wasser mit Pottasche ).  Schliessen Sie alle Zellen mit ?ffnungen zusammen an Gas-Ausgang und Wasserzugang .  5 Zellen f?r 12 Volt DV werden mehr Gas produzieren als 6 Zellen .  Dies ist nur ein Vorschlag .  Pese
because it admits is the fact that car batteries can explode , if one fast-loads this, and use with fire or only transmits  sparks on the electrical cables because the loading (bubbels)t produced hydrogen , if the  loads is stron and to fast  = over 15 V . It is nevertheless only obvious that one can use new or old car batteries also for the HHO production. (Water purely, water with acid, water with potash). Close all cells with openings together at gas exit and water-reservoir  entrance. 5 cells for 12 V of data processings will produce more gases than 6 cells. This is only one suggestion , i cant nothing say if it is enough to run an small or big motor. Possible some members will try it and post it here
Pese
www.pese.150m.com/fe/
www.pese.150m.com/pat/
