Sum of torque
Started by EOW, October 12, 2014, 05:36:02 AM
EOW
QuoteI kind of find it funny that a ring or a disc might be able to use different formulas just because it is either a ring or a disc.
me too... I don't find the formula in Internet but anyway it's works with a ring, and this idea can be use with a ring.
you tested on what software ?
You tested on a real machine ? where you speak about it ? you must apply torque only a red point, ideally the torque must be applied a very short of time (function of the rotationnal velocity), this need sensors, precise electronic control, etc. You built a mortor like that ?
EOW
Trajectories can be like first image or like second image if w1 and w2 are choosen correctly (depends of the radius).
EOW
No, it's not the same principle. My idea is to use external objects (or something external like air), it's very important because your link shows a system "close" nothing external. Or something fixed to the ground that can recover energy. Here all the system turn no ? And like I said, it's not possible to give a torque like that. You must apply the torque when w1=w2, this in a short time, you need sensors and electronic command.
EOW
I don't understand your message, maybe if you drawn an image I can. Where are results of your tests and the model to test, have you image and link ?
QuoteWhere is the torque in your system if you apply an equal force in opposite directions on opposite sides of the disc?
look at image of post #16, there is a torque due to external object (that can be done with fixed and controlled coils). And look at trajectories of points with w1 and w2, it's not a point, it's a line, your coil must recover energy perpendiculary to the trajectory, like the shock with balls for example. It's not easy to build. I don't know your system and if I can watch what you do I can say if it's the same or not.
For my study, the trajectory must be good for have a torque, like image shows. Maybe it's not the best. Choose point at P1/P2 and adjust the mass of object to schock for have the same force (in value).
EOW
Like that, there is a torque ?
