The Resonance Energy Device Secret Revealed
Started by hope-hope, October 18, 2014, 08:47:21 AM
hope-hope
Hello everyone,
Yesterday we released the first document about the resonance energy device,  the device depends on a multidimensional transformer which makes possible a harmonic exchange between the positive energy reality and the unseen negative sea of energy. This is possible
using a spark-gap arrangement, the energetic symmetry between the positive and negative energy oceans make
it preferable to use the term ambient background energy rather than the name zero point energy.
the full explanation available  in the following link,
http://www.free-energy-info.com/Belkired.pdf
All the best.
wistiti
I hope hope
I replicate it but i am not able to get good power at the l2 output...
Any easy tricks???
Thank you
Well, that's half an hour I'll never get back.
Driving a flyback transformer +properly+ at its resonant frequency:
http://www.youtube.com/watch?v=4XRwlNCF1PU
Using the output of a properly driven flyback transformer to properly drive an actual resonant output system to attain _really high_ peak power levels:
http://www.youtube.com/watch?v=aIZClhoU2Xk
Extracting +real power+ from a small, actually resonating, reactive power system using coupled air-core coils:
http://www.youtube.com/watch?v=jcGTBA7NoVI
And not a word of gobbledegook involved.
hope-hope
thanks for the interaction
in fact the E-TBC will supply the reactive power ( this is a phantom power :) ) , the pick up coils will do two things:
1- it will receive the reactive power using what we call the receiver coil Lr, this coil need to be tuned for the same working frequency as the E-TBC using a parallel capacitor, because the E-TBC penetrate inside Lr the obtained power across this receiver coil in still reactive the parallel capacitor will do another shift for the voltage to be the same phase as the current...
2- now it's the turn of the transfer coil (Lt) to do the rest of the job, this coil has to be isolated from the receiver coil using only two diodes.. parallel added diodes will let more current but we have to take attention to this point!
we are using RADIO FREQUENCY , so we have emitter and receiver, Lr and Lt  act like antennas, but in Lt we will get the corrected phase that will be accumulated in the capacitors banks easily, for a capacitor to build a good voltage we need a current, because there is a phase shift in our E-TBC it's IMPOSSIBLE to get the active power needed!
tuning Lr and Lt is crucial, people with good hardware are invited to do this job so we could know the frequency range for a determined prototype, making it easy for others to replicate this device.
  i will post two photos to show that , in the pick up coil we don't use an usual diode bridge because the concept of antennas exist here.
