The Resonance Energy Device Secret Revealed
Started by hope-hope, October 18, 2014, 08:47:21 AM
hope-hope
the following is a just a though about how the collection system work.
using an extended Tesla Bi-filar coil will produce both hot ordinary electricity plus cold radiant electricity, the way an E-TBC oscillate make it able to produce both Cold and hot electricity perfectly without cancellation effects!
using an ordinary methods to collect the available power will not work good because in a positive regime time Cold energy will cancel Hot energy, the obtained power will remain too low to produce an OU device... in other words an E-TBC will produce hot electricity with the same speed it produce radiant electricity, a special care must be taken to collect the available energy. reviewing my document about the resonance energy device we have
For the first time period, we have (C discharging across L) + energy increase magnetic energy ---- I - energy increase electric energy ---- V
For the second time period we have (L charging C) + energy increase electric energy ---- V - energy increase magnetic energy ---- I
to simplify the things let take the first sight when the capacitor discharge across itself to be a full parallel L/C circuit, at this moment and before the current start increasing, negative energy will push the current to go back against the voltage in action at a distance (because it will start from X point ) similar to what happen when the current flow in ordinary hot electricity it produce magnetic field but in this case the current in cold electricity will increase the voltage statically! when the turn come to hot electricity to play negative energy will cease .... please read page 15 in http://free-energy-info.com/Mohamed.pdf to understand the things clearly, the construction method used in hot ordinary electricity can't suit cold radiant electricity....!! please see page 9 in the above document when i explained how an E-TBC work in both positive energy ( future light cone ) and negative energy ( past light cone), in the wrapped negative energy space the current start from B to A which oppose the flow of current in hot electricity, this current charge the coil electrically like it act as a capacitor... take into account the positions of coil and capacitor in an oscillating E-TBC, the destruction method used in hot electricity is constructive in cold electricity, we need this information to understand the cancellation effects that appear when we use ordinary methods to collect the available energy, Before an E-TBC discharge (this is destruction effect) across itself from A to B, Cold electricity will act in a reverse manner providing a virtual current which charge the coil from B to A (this is construction effect). in the second sight when the collapsing magnetic field charge the capacitor from C to D, just before this operation, the voltage in the virtual E-TBC take its maximum value from D to C (in our positive energy future light cone we have a maximum magnetic field at this moment), when the voltage decrease in the virtual E-TBC ( this is destruction effect - after that the magnetic field will collapse) the wrapped space in the positive energy future light cone see this as a short-circuit and provide a maximum current (this is construction effect), this is why this energy will charge the capacitor magnetically if it act as a coil !!
the design of our ordinary coils and capacitors will not provide the best timing for this kind of energy to be perfectly stored and then used, why ? cold electricity is a reverse kind of hot electricity... when we charge an electrolyte capacitor using the hot electricity taken from L2 coil (construction), cold electricity pass a current in a reverse manner to our ordinary hot electricity ( destruction )... similar to back EMF when a coil reverse its polarity. using standing waves is a clever idea to separate destruction area (Node) apart from construction area (Antinode) using a quarter wave length, using this technique will force L2 coil to take the power from an E-TBC perfectly please see the attached drawing. in my opinion this is a physical separation where we could provide the best place for cold electricity to destruct its reflected wave rather than destructing the constructive waves.... in the construction area ( Antinode) even if the moving real wave move in the positive direction (increasing) and the reflected wave move backward ( decreasing ) , the antinode is a construction area all the time ... this idea isn't complete in my mind but i think this is how to collect the huge available electric energy using our E-TBC
Good night.
@hope-hope
I'm glad you watched my videos. Some other people must think my "laboratory" isn't quite adequate, since they call me an eccentric broke miser with garage-sale equipment... but at least I know how to use what I've got, which is more than I can say for some others with much more expensive kit.
(By the way not a single piece of the gear that I use was actually obtained at  "garage sales". My HP180 scope was used at Lawrence Livermore National Laboratory in the development of nuclear technology and was given to me by a scientist who worked there; my Tek RM503 scope came from NASA Ames Research Center surplus property sales, for example.)
No amount of theorizing can trump even the simplest experiment or demonstration. There is much in your last two posts that I disagree with, some that I can agree with. Here is the most significant thing you have said, in my opinion:
Quote from: hope-hope
in fact i don't have an oscilloscope neither a frequency meter or L/C meter.
The oscilloscope is truly the King of Test Equipment, and I am continually amazed when I find that people who are discussing theories about "radiant energy" and "frequencies" and "resonance" and such topics don't actually have one, or don't know how properly to use one that they may have.
May I suggest that you obtain at least an oscilloscope, then start doing some experimentation of your own. You may find that you will learn a lot in this manner, more than you can possibly learn by reading internet sites.
Do not be fooled into thinking that only an expensive digital sampling oscilloscope will meet your needs. There are very many excellent used analog oscilloscopes on the market that any serious researcher would be proud to own, and even if you have as little as 200 dollars to spend you can set yourself up with the basics that you need. You can build a function generator yourself for a few dollars; you can measure frequencies and inductances adequately with an analog scope and the function generator; you can even use an Arduino and a few external components to make your own inductance/capacitance meter. You can get a reasonable "starter" usb-based DSO and a set of probes for under 100 dollars US.
So start doing your own experiments, to try to confirm or falsify the testable points in your theorizing. You may be pleased with what you find out, or disappointed. Either way you will learn valuable lessons.
Pirate88179
Quote from: TinselKoala on November 26, 2014, 09:13:24 PM
Wow, that's one hell of a "garage".  They were one of my customers when I was in the precision ceramic machining business. NASA Ames was also.
You are correct about decent equipment being available.  I got my Tektronics 2213 scope on ebay a few years back for $100, including $20 for shipping.  I also got a Goldstar OS-904RD 2 channel scope for free from a guy at work that wanted to get rid of it.
It does help to have opinions of guys like you, and others on here, before buying one though.  I appreciate the advice you gave me before I obtained my power supply. (which still works by the way.)
lsd2015
hope-hope, can you explain why load does not effect input in the don smith device using your theory?
and i have notice current is always phase shift 90 degree to voltage in a normal parallel LC,i have test this using
a current probe and voltage probe today.
hope-hope
@   lsd2015
the coil wire in the E-TBC form the capacitor plate at the same time... what does this mean ? it mean the device is able to receive ambient electrons when it deliver it, so in the pickup coils you will have a squared amplified electromagnetic flux   ;D
the reason of power amplification is the induced rotating electrical fields, this fields circulate the E-TBC in an attempt to cancel the change made in the system, please re-read my document for more detail  http://free-energy-info.com/Mohamed.pdf.
in the first sight wen the spark form the full parallel L/C  circuit, the current increase but the voltage will not decrease like ordinary parallel L/C circuit because the induced rotating electric field will build added elementary voltage which in turn make difference of voltage between adjacent turns , here we could achieve high current with high voltage since the voltage will go back to initial value when the current increase...
THE CAPACITOR IN THE E-TBC is a reference to something exist BUT CAN'T BE SEEING  :),  this is why we call it one dimensional capacitor that will open the correct door for negative electricity to enter into our device using the flexible spark-gap zone,  the word flexible here mean it's able to let the exchange to be done between negative and positive energy seas without problems, in other words it will let the space to be wrapped from + energy toward - energy and vice versa ....
the phase shift in the E-TBC mean the presence of one dimensional capacitor which in turn will be a no linear function with the inductance of the E-TBC.
why the load don't affect the input is another story.... the things are related with each other strictly, according my understanding the device will supply both -electricity plus +electricity, a special care must be taken to provide the best timing  for these reversed kind of electricity to be united correctly in the capacitor banks and then switched according custom need  OR  cancellation effect will take place!
