solar activity and crystal cells
Started by jonfrommanahawkin1, October 25, 2014, 12:16:47 AM
jonfrommanahawkin1
I've been working on a new type of crystal oxide, however I was wondering if anyone else was getting unusual readings from their cells in the past few day because in the beginning of the week my cells had some dramatic readings and as the week passed I've had to change my formula to duplicate the same effect
Call me crazy but at first I was almost convinced the cells were reacting to "good energy" and now after learning that there was alot of solar activity in the past week I was wondering if anyone else was getting unusual readings
Even ambient atmosphere electricity has been very high, that's not unusual however I just want to ask so that I don't chase a reading that I may not be able to duplicate
All the best
Jon
ps regardless I will post my findings when I work out the kinks
profitis
jonfrommanahawkin1
Well I'm calling it an oxide, more specifically a "nanocrystal oxide".I think Bedini did something similar however I'm not sure exactly what he did because he was more focused on making the cathode a semi conductor, where this "nanocrystal oxide" is more focused on being the electrolyte. But when it works it's so random.
The crystals im using are aluminum sulfate no salt and iodized salt dissolved in solution  and sometimes trying epson salts and borax to try and stabilize the current but ever day regardless if the cell is fresh old or identical readings are different
It's so aggravating
profitis
Aluminum sulfate will instantly precipitate aluminum hydroxide gel with borax.so it'l be a mix of aluminum hydroxide gel and sodium sulfate in the pores of the hydrated quasi-solid electrolyte.if I knew the identity of the anode material I can tell you exactly what's going on
jonfrommanahawkin1
I've been trying two cathodes, one is a pure nickel ribbon and a nickel plated steel ribbon and a pure magnesium anode
I try to not use the borax and epson salt because it seems to limit the current but sometimes it seems to increase it?
