GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
Quote from: poynt99 on October 31, 2014, 10:51:33 AM
That is not entirely true MH.
Companies ship their uncertified products all the time to Canada. I work with countless pieces every day, and I have in the past as well.
All you need is a "special inspection" sticker applied to the device to have it legal in Canada. These can be applied on a case by case basis. Just call CSA and ask them to come out (or take your unit there).
Now _that's_ a video I'd like to see.
"Er, Mister Potter, you say this device runs on _water_? Here, let me hook up my test equipment and a proper load bank to it."
MarkE
Quote from: Nink on October 31, 2014, 02:45:27 PM
OK so I figured I would build a water powered engine.  Now don't just think I took a CD rom with magnets on it and taped it to a drinking bird.  I think I am going to be short  about 14999.999 Watts https://twitter.com/NINK/status/528252772291207169
That's just a small scaling and optimization problem.  Investors need to get in on the ground floor now.
Nink
Quote from: MarkE on October 31, 2014, 04:37:06 PM
You are absolutely right, I just launched a new company Drinking Bird Systems (DBS) and  I am taking pre orders now.  Don't forget to buy my tshirt  /sarcasm
BTW it appears you can no longer buy the tshirt from GDS, did anyone get one ?
MarkE
Quote from: Nink on October 31, 2014, 05:30:24 PM
When PESN picks-up on your discovery, I hope that you will give them an interview.
TommeyLReed
Hi all,
I like to add my two cents to this GDS Technologies, I believe it's not what they have claimed.
Working with water power projects in the past you can clearly see when Greg Potter( I could not find this person on the internet of any past comment) showing the machine running with the top off and in 5:00 video time.
You can see the dc motor running and a belt powering a permanent magnet generator or pressure pump but,  that turbine was not spinning at all.
If this was a water power turbine, you would expect to see the turbine spinning, why was it stopped?
I did a few calculation and eveny time I adjust pressure & volume need to produce power in a water turbine it's always showing a loss.
AS we all know that hp= PSI * GPM/1714 is the amount of mechanical work needed.
Everytime I try to get power output their is a 50%-60% lost due to friction and other factors. No different then a gasoline engine producing 1 kw taking up to 2hp in mechanical work in gasoline engines and 1.5 hp for diesels.
I believe it's another scam when you start looking at the numbers.
Tom
