Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
Quote from: TinselKoala on August 12, 2015, 09:52:10 PM
Both channels have bandwidth limiting turned on, and CH2 is AC-coupled. Why?
CH2 is now DC-coupled.  Shall play with bandwidth limiting off.
Bottom diagram has BW limiting off on both channels.
MarkE
The spikes you see in the current waveform are aberrations caused by the ESL of the big cement resistor.  The total voltage across the resistor is the vector sum of I*R + ESL*di/dt.  The ESL*di/dt term distorts the leading and trailing edges.  You can either change out the cement resistor for a low inductance resistor, or compensate the response.  You probably don't have the equipment around to compensate the response so you should buy a current sense resistor that is low inductance.  Invest $6.00 in one of these:  http://www.digikey.com/product-detail/en/13FPR100E/13FPR100E-ND/998513.
ltseung888
Wave form analysis possible with the Atten DSO.
The values of Current (voltage across 1 ohm resistor) and Voltage across the iron-core Coil) can be captured and analyzed.
The BMP file and the Excel graphs are displayed for comparison.
MarkE
Until you clean up the meaurements, it is a case of garbage in / garbage out.  Rosemary Ainslie used cement resistors and two sides of a wire for her current measurements and got completely bogus results.  At least in your case, your scope probe is across the resistor.  You should be assking yourself what could cause the current to overshoot as indicated by interpreting the current viewing resistor voltage as I*R.  Circuit inductance resists changes in current.
ltseung888
Quote from: MarkE on August 13, 2015, 03:47:00 PM
Since Hong Kong University has taken up the experiment as student projects, I shall let them do much more vigorous scientific research.  They have better equipment and resources.  Other academic institutions are likely to join.
My job is to sow seeds.
I am sure that USA and Chinese Military Researchers have done similar experiments and some UFOs are already flying.
Lawrence
http://www.overunityresearch.com/index.php?topic=2100.msg50206#new
