Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
The presentation as of Sept 9, 2015.
Spent some time at the Senior Center showing the information on the Internet.  One comment was:
"Use the Internet well.  It is free.  Do not carry the information to your grave.  At our age, everyday is a blessing and a bonus.  Use it well."
Another comment:
"I cannot full comprehend the information.  But there are others more qualified than me who may understand.  My grandson is a good example.  Please put him on the email list."
The latest presentation file is attached.  You are welcome to share it with others...
Divine wine is to be shared.
ltseung888
How would the new paradigm change the World?
The new paradigm promises abundant, non-polluting energy and unlimited transportation.  How would the present order of society be affected?
This must be answered before the technology gets rolled out.  This may be one of the reasons that China and USA are keeping the lead-out energy flying saucer top secret.
The technology is known.  Flying saucers are hovering all over the planet.  The visionaries must play the what-if scenario before the ugly and heartless Politicians.  The technology must be used for the Good.  It must not be controlled by the Evil...
T-1000
Supporting information:
http://www.siriusdisclosure.com/
http://searlsolution.com/technology3.html
This stuff is usually ignored by most but for open minds it have huge value..
ltseung888
The third design of the two Ferrite-rod Core Coils.
This design has the advantage of simple construction.  Instead of a hole and a guide rod in the middle, two or three holes and guide rods are placed outside.  The Ferrite-rod Core can be easily and tightly wound by the copper coil.  The triangular plate can be thin and glued onto the Ferrite Rod or Rod bundle.
The suggested dimensions are:
1. Ferrite-rod core diameter   5 cm
2. Length of triangle   20 cm
3. Diameter of copper wire   2 mm
4. Number of turns of wire    1,000
5. Height of Cylinder   5 cm
6. Width of triangular plate  2 mm
7. Size of Guide Hole   1.5 cm
8. Diameter of Guide Rod  1.3 cm
9. Length of each Guide Rod  1 m
10. Voltage of DC Current can vary from 1 to 30 Volts (adjustable)
The above suggestion can be modified depending on the material available.
Lawrence Tseung
See http://www.overunityresearch.com/index.php?topic=2100.msg51962#msg51962
ltseung888
Fifth design of the Ferrite-rod core Coil.
One approach is to pass the responsibility to "experts" and wait.
Another approach is to discuss amongst non-experts and see if the Chinese Saying works.
"Discussions amongst three lowly, smelly workers can come up with ideas better than the most learned person."
Lawrence Tseung
