Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
The Second job category is related to the Lead-out Energy Flying Saucer technology directly.
There will be many jobs related to basic research, applied research, engineering, actual product production, marketing, maintenance etc.
Man made UFO from USA and China are flying.   Reply 1 of this thread outlined one possible design.  There will be alternatives.
The design will be turned into working prototypes - probably by an unexpected Country.  The race will then be ON.  Billions of dollars will be poured in.  The new paradigm will begin.  It will ellipse all known inventions in Human History...
ltseung888
The New Paradigm of Lead-out Energy Flying Saucer is coming.  Man-made UFOs from USA and China are flying.  These UFOs can:
1.   Hover, take off and land vertically similar to a helicopter
2.   Do sharp turns as they do not rely on aerodynamic forces
3.   Use energy from the environment and need no chemical fuel
4.   Can fly to outer space if needed
5.   Do not need to eject hot gases out for propulsion
6.   The technology can be used to reduce effective weight of cars, trains and ships
7.   The technology can be used to generate electricity without chemical fuels
Both China and USA have such man-made devices flying and operating.  We were made aware of them since 2006 at Tsinghua University in China.  There was a 225 HP Pulse Motor funded by Mr. Andrew Wong of Yuen Fat in Hong Kong – developed in USA.   There was an Energy Multiplier that could lead-out gravitational and electromagnetic energy from Tsinghua University.  That Energy Multiplier could have output energy 30 times that of the supplied input energy.
The first UFO we were aware of in China using such technology was in Nanjing 2006.
https://www.youtube.com/watch?v=DbSSTqlanS8
The Milkovic two stage pendulum demonstrated leading-out gravitational energy.
https://www.youtube.com/watch?v=gC6Qlj1Mbo8
1.   At 2:07 time, the 46 pound pendulum was at its maximum height position.  A small push with the fingers lifted the 74 pound weight twice.
2.   Between 2:07 and 3:30, note that the weight was lifted twice with each push from the fingers.
3.   The weight was lifted when the pendulum was at the lowest height position.
4.   That position was the highest velocity position.  The centrifugal force was highest.
5.   Notice that the maximum swing position was hardly changed.
If we can lead-out or bring-in gravitational energy, we must be able to bring-in magnetic or electromagnetic energy via a magnetic pendulum and artificial magnetic fields.
The New Year of the Monkey Card showed the most important concepts.
More details are available in overunity.com.  Search using "UFO propu".  Reply 1 shows the possible design of a lead-out energy flying saucer.  The angular velocity at the top can be much higher than that at the bottom.  The resulting centrifugal force difference will provide the net thrust to move the device upwards.
Lawrence Tseung
Lawrencetseung@yahoo.com
Lead-out Energy Research Club
Feb. 2016
*** The one page file is available at St. James Settlement as a handout for the visitors.
ltseung888
Back emf energy
The attached diagrams showed the results of the solenoid repulsion experiment done on Feb 29, 2016.
1.   The 540 turn coil was used.
2.   The combined mass of the 5 magnets + PVC tube = 126 gm
3.    The Height jumped was 40.1 cm at 17.5V
ADS00017.jpg showed:
  Top curve = the Current (CH1) = Voltage across the one ohm resistor.
  Bottom curve = the Voltage (Ch2) across the solenoid.
ADS00018.jpg was the same data but focused on the leading edge of the pulse.  Note that the time interval unit was 1ms instead of 100ms.
Back emf energy.jpg showed the emf energy at the leading edge of the pulse.
From the results, there was definitely a back emf.  This back emf did have energy.  One possible explanation was that this energy was the lead-out energy.  In other words, the DC power supply provided X units of energy.  The Back emf provided Y units of lead-out energy.  The resulting Input energy to the system was X+Y units.
The proposal is to change the experiment from straight-line repulsion to unbalanced wheel repulsion.  The pulse will be very short but the lead-out energy will be much higher if the speed of rotation is increased...
ltseung888
The waveforms of the solenoid only is shown here for comparison.
The Pulse waveform is shown on LHS.
The Leading Edge of the Pulse where the back emf is clearly present is shown on RHS.
ltseung888
Quote from: ltseung888 on February 28, 2016, 06:43:52 PM
The back emf energy is interesting.  Can we increase that with presence of ferromagnetic materials?  Will the more ordered dipoles provide more magnetic flux and thus bring-in more energy?
This category of jobs require much scientific training.  The training itself will provide many job opportunities...
What are the meaningful economic activities once a Nation has overcome problems in feeding, clothing and feeding its people?  What is the difference between a developed nation and a developing nation?
