Ufo propu engine, closed loop
Started by ingyenenergiagep, November 07, 2014, 01:34:16 PM
ltseung888
Quote from: ltseung888 on May 17, 2016, 06:44:11 PM
The Bill Fung Project Update.
Co-ordination from Senior Citizens not perfect.
1.  Design done (reply 1 of this thread)
2.  Vertical repulsion of magnet by coil done.
3.  Waveform at leading edge of the pulse showed positive Current and Negative Voltage.  This indicates plausible lead-out energy.(see pdf)
4.  Circular motor on Unbalanced Wheel can be maintained if properly pulsed.
Theory correctly pointed to right direction.  More engineering needed.
pulsing control can be achieved via
1. reed switch as in Newman motor
2. proximity switch as in Tong wheel
3. optical sensor as proposed in Fung wheel.
The cost of such switches are in the order of a few US dollars.  They should provide more reliable performance than humans.  DSO results will be more accurate.
Top Chinese, US or Russian scientists can do better...  Have they built UFOs?
ltseung888
Quote from: ltseung888 on May 23, 2016, 03:28:52 PM
The initial research cost of UFO is thousands of dollars.  The benefits are in trillions.  Does it make sense for a Nation to invest in such a technology?
The Physics is clear.  Can the engineering difficulties be overcome?
The main worry may be politics...
ltseung888
Quote from: ltseung888 on May 24, 2016, 05:38:29 PM
Clean, abundant energy
Travel anywhere including outer space
Dive under the ocean if desired
Get rich together with other nations
Reply 1 of this thread is worth more study.
ltseung888
Quote from: ltseung888 on April 21, 2016, 03:47:20 AM
Discussion with an Engineer.
1.  A simple pendulum needs to overcome air resistance and the friction at the pivot.  That can be very small.  We can easily achieve 99% efficiency.
2.  If the simple pendulum is connected to a seesaw in the Milkovic 2SO fashion, the up and down motion of the weight is automatically maintained.
3.  The maintaining of the up and down motion is NOT via static forces but via the centrifugal force.  Please study the Raymond Head video 6 very carefully.  The weight is lifted twice for every finger push.
4.  The centrifugal force mechanism is "free" by the pendulum swinging motion.  So long as the pendulum swinging motion is maintained, the up and down motion of the weight is also maintained.
5.  The up and down motion of the weight can be used to do work - such as producing the loud bang, crash nuts or pump water.  In the Raymond Head video, the pendulum swings back almost to its original position.  The up and down motion  of the weight produced the loud bang and must have done some work.
6.  One possible explanation is that gravitational energy has been led-out in the process.
7.  The simple pendulum is not very efficient as the energy led-out is occurs at the highest centrifugal force position.  Or when the pendulum bob is at the lowest position.
8.  We can improve the Milkovic 2SO by replacing the pendulum with an unbalanced wheel - the Chan wheel.  The rotational speed can be increased and more gravitational energy can be led-in.
9.  We can further improve the Chan Wheel with Cylinder.  A Cylinder can be thought of as many wheels put together side-by-side.
10.  We can further improve the mechanism via leading out of electromagnetic energy.  A ferromagnetic magnetic material can be thought of as many tiny magnets arranged in random when there is no electric current.  If DC current is passed, these tiny magnets can be aligned to produce a large magnetic field.
11.  The Tsinghua University Energy Multiplier leads out both gravitational and electromagnetic energy.  The Output can be 30 times Input.
12.  UFOs are flying.  Some of these UFOs are made in China or in USA.
Engineer: "The Bill Fung project is doomed to fail.  The construction will not stand the high rpm.  You need at least 800 rpm to show the difference in centrifugal force.  The unbalanced weight is the magnet that has insufficient mass.  The diameter of the wheel is too small."
Fung: "My purpose is to further illustrate the design in reply 1.  It gives me something to think about."
Engineer: "There is no point in doing an experiment if it cannot fulfill its goal."
Tseung: "Research has its surprises.  We did not foresee the leading edge shape in the coil and magnet experiment.  That can be interpreted as a clear indication of lead-out energy."
Fung: "I shall spend my time between USA and Hong Kong.  At our age, we do not demand success.  My goal is to enjoy life and contribute whatever I can."
Tseung: "UFOs from China, USA and Russia etc. are flying.  My goal is not to build an UFO.  My goal is to get more scientists and engineers to realize that Humans can build UFOs.  Wealth of Nations can be via knowledge.  Knowledge has the property that the more you share, the more you will have.  A Nation can get rich and maintain the wealth via getting other Nations rich."
ltseung888
Discussion at a clinic when some friends met Tseung at an eye clinic.
Friend 1: "I saw the old lady video.  You should find somebody better."
Friend 2: "It is actually very good.  Any viewer can say that he can do better."
Tseung: "I am trying to find somebody now.  Can you recommend any?"
Friend 1: "Do you know that you can make someone really famous and wealthy if your UFO technology actually works?  You can even make a Nation wealthy."
Newton made England rich with his Laws of Motion that laid the foundation of Science.  The Lee-Tseung theory will bring out almost inexhaustible energy and foundation to travel to Space.
Friend 2: "Will anyone risk his/her reputation or time to work with you?"
Friend 1: "Find someone with nothing to lose..."
Tseung: "Good idea."
