The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
gotoluc
Quote from: ariovaldo on January 14, 2015, 08:01:57 AM
No problem my friend...
The video below is my project update...
I don't have to much time to work on it, but I hope that I can have this running until the end of February...just for learning...
https://www.youtube.com/watch?v=3lF5xT6oDm4
Thanks
Quality build ariovaldo!
Looking forward to your tests
Thanks for sharing
Luc
Jimboot
Thanks
Wow looking great. Well done.
thngr
Thanks
thank you for your effort while learning to share it with us.
we are willingly looking forward for your results.
Grumage
Grumage
Quote from: MileHigh on January 14, 2015, 01:08:31 PM
Grumage:
For starters, when a coil output drives a load resistor, it's always prudent to calculate the power dissipation in the resistance of the coil itself and in the load resistor.  It's a point I hammered away at a while back because it's important.
Obviously, you have conflicting data if you calculate 17 watts dissipation in the 0.1 ohm resistor and the 0.1 ohm resistor stays cold.  That simply doesn't make sense.  And then you say to yourself, if my 0.1 ohm resistor is dissipating 17 watts, how much power is being dissipated in the coil winding resistance?  If you go strictly buy the numbers, chances are a much greater amount of power would be dissipated in the coil itself.
I don't know much about your setup except for watching the one clip.  But it appears that there are some issues to ponder because the numbers don't look right.
Dear MileHigh.
Indeed, they don't !!
It seems I misread my resistor, try substituting 100 Ohm for 0.1 Ohm !! Gyula spotted it over at Energetic.
I am publicly announcing my mistake and extend an apology to you and our members alike.
Cheers from a rather red faced Grum.
