The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
prochiro
MCR
If you get to changing the spacing, do not add more space between the coil and deflectors but you can take the magnets, depending upon there strength, away from the iron. I really think that when RPM is increased that there will be less yet at a relative sweet spot.  Have fun.
Prochiro
prochiro
MCR
It is a good thing to have two separate jugs as I also understand and know a lot about your own work.  This is just one example of what you were working on but taken to the next few levels.
http://www.overunitybuilder.com/generators.html
OVERUNITY BUILDER  - - - on Youtube , all should see his videos.
http://overunitybuilder.com/toy.html - - is also video all should see further down this page as to magnet/coil action.
http://peswiki.com/index.php/Directory:Daniel_Quale_Lenzless_Generator
This is a fun place... 8)
Prochiro
Jimboot
Quote from: Mister Caribbean Roots on January 27, 2015, 06:41:14 PM
Hi Prochiro,
You are giving me to much credit there... :o ...i'm just doing what i can with what i have... ;D
Just done making a whole bunch of parts for my own projects including a 8 pole rotor but with ferrite bars... 8)
In other flux gate setups like the one in the link you wrote ferrite don't work so well but since this one from T1000 is a bit different i wonder how good they will work... ;)
If it does work that would be good since ferrite doesn't have the issue of eddy currents... 8)
I have all the stuff already for a seperate setup of T1000 design... ;D
Since i've never made one like this it will be a fun and learning process for me and that's always a good start...lol... :P
I just need to make up my mind...horizontal or vertical setup and 24 or 36 magnet one...choices choices and more choices... ::)
But it's always good to have the choice of choices...lol... ;D 8) :P
Cheers
I'm thinking vertical now. Grum said it lowered his input cost
Thaelin
Jim:
   Just a thought for you. If you are going to run the rotor with a vertical
shaft, make sure to use that type of bearing made for it. Otherwise you
will have wear where it wasn't meant to be.
   Then more drag.
thay
Mister old news
prochiro
gotoluc and jimboot
I see that you are discussing bucking coils in the other forum. The following is the best PDF about what to and what not to do when using this coil setup. It is like a bucking coil  bible. Others should read this also as it gives a complete 180 degree spin on what we are doing here.
www.hyiq.org/Downloads/Guidelines%20to%20Bucking%20Coils.pdf
Prochiro
