gotoluc
lumen
Quote from: free on December 08, 2014, 06:45:23 PM
Yep, it is no different and that is why i wrote in the comment section that cored coils don't seem that bad after this test... ;) :P
This cogging was just ridiculous...never felt anything like it before... :o
Well, good thing we have the lenz effect because without it we won't have any energy production when using a coil/magnet configuration... ;)
Cheers
free,
The main problem I see is not so much the cogging but eddy currents in the iron causing lenz and heating drag.
If you used laminated iron it would operate with the same cogging but would have much less drag.
Even then, the energy out would not be OU because the setup still sees lenz in the coils.
I am going to build a version of the design I posted earlier where switching takes place within each coil and nulls the field between each polarity change.
It appears to me that the lenz would only serve to help rotation. (so I think anyway)
Good Luck!
Just..Sayin..
Quote from: vince on December 07, 2014, 10:52:26 PM
Some Update
I wound two of the 6  output coils with 18 gauge wire for my generator and did some quick  tests. Not sure what to make of the results so maybe I can get some opinions.
I powered 2 of the 6 field coils opposing the 2 output coils that were wound with a 12 volt dc battery charger and i drove the main dc motor with a pwm . Both the field coils power and the motor power were plugged into the same watt meter.
open circuit no load on output coils
RPM 3105
Watts in  575
open voltage out  6.90 dc  2 coils in series thru a bridge rectifier
loaded circuit with 10 k resistor shown below
RPM 3105 (no change)
Watts in 575  (no change)
voltage across resistor .445
shorted output coil
Vince
That there is no change to the input when shorting the output coils is a successful test. Very successful and very encouraging.
Edit... Vince you have confirmed what Syair has claimed and convincingly demonstrated, that back emf can be overcome by employing stationary induction coils and stationary field magnetism, which is interrupted/switched with ferrous rotor segments. The overall machine efficiency in your test was irrelevant.  Thanks very much for your contribution...... I am also working on a similar test that should have great overall machine efficiency and substantial induction efficiency....(if your test results are what you say they are)
The energy we have been putting into conventional alternators/generators to turn the shafts and create electrical power has not been the energy we have been taking out of the machines.... The input power has been used to overcome the resistance between the supplied field and the induced field. The input has always been consumed by the struggle between the two fields. The supplied field and the induced field.
No known laws of physics are being changed with this induction method, the known laws are now being seen in a new light, and employed differently. In reality, very few laws of physics are known when it comes to grand totality of God's creation. We are still entirely clueless as to what makes magnetism actually tick.
Physics has been taken in by a great delusion and a sleight of hand. Why? Because the power needed to overcome the struggle has been precisely the same amount of energy that comes out of the machine. Therefore people assumed it was the transfer of one form of energy into another, when it was not.  It has all been a hoax! Electricity has always been generated from an endless supply of free magnetism. Counter electromotive force, or the lenz effect, has been a great deceiver from day one.
I'm standing in my back yard spraying water around with my garden hose. I have a flowmeter attached to the hose and I make a reading. Then you come along with a bucket labelled "output" and run through the yard catching water from the spray in your bucket. Look! There is no change in my flowmeter reading!
A successful test of the Overunity Garden Hose! Very encouraging.
Cap-Z-ro
" I'm standing in my back yard spraying water around with my garden hose."
Words spoken at least once by every guy drunk and alone in his back yard.
I'm here all week...try the veal...
