lumen
Delay in coil current is Lenz delay because the coil current is Lenz.
To delay the coil current offers no advantage, if delayed over 90 degrees the current is simply never produced and no work can be gained.
The entire process of phase shift or resonance to gain energy is simply not true and is fully understood.
There may be a way to remove most of the undesired lenz effect but lenz in the coil is required and is a result of work being done by current flow.
It's just not necessary for lenz to work against the rotor of a generator.
gotoluc
I've been thinking of this effect for a while and what keeps coming back to me is, it seems to be quite the same effect as JLN has noticed when testing Thane Heins ReGen-X coils and found he could produce the same effect just by having more core material between the coil and magnet (as picture)
Could this not be the same effect?... since syairchairun design does adds more distance and core material between coil and magnet?
Just thinking here ::)
JLN video demo of the effect: https://www.youtube.com/watch?v=YUoyuiQTrRA
Luc
lumen
gotoluc,
I think what is shown in the video is misleading.
When the shorted coil is close it causes additional drag from Lenz.
When the shorted coil is moved away just right, then the Lenz causes a neutral field in the iron bar and consumes the least energy.
When the shorted coil is moved further out the iron bar consumes more energy because of induction heating and hysteresis in the iron bar.
Lenz is simply the field produced by the current in the coil. The same as if you connected a battery to a coil.
Battery current to coil = magnetic field,       magnetic field to coil = current.    It's the same thing!
Now for the way around Lenz!
When the magnetic field loops from a permanent magnet contact an iron core of a coil some domains align with the field making the iron a magnet. Now more magnetic loops are attracted and more domains flip making the iron a stronger magnet which attracts even more magnetic loops.
Stick with me because I will tell you the only way to defeat Lenz.
Now, If the iron was wrapped with a copper coil and shorted as a load, then the loops that pass through the coil and enter the iron also induce a current in the coil.
The iron only serves to help keep the loops inside the coil because if they move outside the coil then for every loop that leaves you need another moving inside just to stay even.
The current produced is in the direction to produce a magnetic field opposite the incoming magnetic loop direction so it prevents more loops from entering the iron. This is Lenz!
To make more current you need to force the loops into the coil and this requires more work.
To get around the Lenz problem,  you put the magnet and the core inside the coil and use iron to pull the loops outside the coil.
With this reverse Lenz effect as the iron attracts the loops outside the coil they must pass through the coil inducing a current that instead attempts to retain the magnetic loops inside the coil. Whatever is held inside the coil causes less attraction to the rotor that's trying to pull the loops out.
If this was designed well, you should be able to pull as many loops out through the coil as you could push into a coil in a typical generator. The difference would be that additional load would not need additional work from the Lenz effect because you have reversed the direction of Lenz by inverting the magnetic field in the coil to the rotor direction.
gotoluc
Thanks lumen for posting both your opinions and understanding.
Maybe the Lenz delay will slip by you know who ;)
Thanks for sharing
Luc
Luc:
I looked at the JLN clip and I am not impressed.  You have probably heard that water is an excellent analogy for electricity.  The water pressure is the voltage.  The water flow is the current.  A water resistor is just a long thin hose, there is friction between the moving water and the walls of the hose.  A water capacitor is just a big tank of water.  A water coil is just a big coil of hose.
Please see the attached graphic of a simple water wheel.  That's a perfect analogy to a simple pulse motor.  The water flows out, hits the fins of the wheel, the wheel spins at a certain RPM and all the water ends up on the ground.  Just like a pulse motor, there is no useful output from the water wheel.  Both the pulse motor and the water wheel only have one output, heat.
Now, if you make slight adjustments to the water valve the speed of the wheel will change.  If you make slight changes to the angles of the fins on the water wheel the speed of the wheel will change.
Compare that to JLN's experiment.  He makes some adjustments to his setup, and the current consumption will undergo a slight change, or the RPM of the rotor will undergo a slight change.
In both cases, the changes will make slight changes to the power draw, it might go up a bit, it might go down a bit.  Another way to state that is that the impedance of the water wheel will change slightly, and that will affect the power draw.  Likewise, the impedance of the pulse motor will change slightly, and that will affect the power draw.
So what's so remarkable about that?  You know when people make a circuit to power a CFL or a LED lamp, sometimes they put a big current limiting resistor at the battery positive terminal.  If you change the value of that current limiting resistor slightly, then the brightness of your light will change slightly.  Would you say that changing the value of the current limiting resistor is an "advantage?"  Well that essentially is all that you are seeing in that clip.  He is changing the electrical impedance of the pulse motor.  Sometimes the impedance goes up, sometimes it goes down.  BFD.
In this context the shorting or unshorting of the coil is essentially irrelevant.  It just changes the motor impedance and slightly affects how much waste heat is produced by the motor.
That's what's really happening in that clip.  It's like turning the volume up or down on your stereo and claiming an "advantage."
Quoting JLN:
QuoteHarnessing the Delayed Lenz Effect with an experimental Test Bench
He is not harnessing anything.  He is just changing the impedance of the motor.
QuoteHere an interesting experiment about the Delayed Lenz Effect which shows that the normal Lenz effect can be reversed with a special setup.
That's a retarded statement.  Nothing is being reversed, he is just making impedance changes to the setup.
I have said several times before that I am not impressed with JLN, and that clip only serves to reinforce my impression of him.  He is looking at that setup and does not seem to be aware that it has no significance.
