MarkE
Quote from: NoBull on December 26, 2014, 04:43:05 PM
When they started pumping, the electrolytic caps started bulging out so they gave up until a vacuum immune RF amplifier is obtained.
Other than that mentioning a vacuum chamber without a vacuum is pointless indeed.
The bottom line is that the tests that involved very small forces were not conducted in an environment that eliminated forces from ions formed in the surrounding atmosphere.  The test results are GIGO.
ramset
Mark E
you work in sanitation now...... garbage in Garbage out??
Actually some of us can read too...
there is no bottom line yet ,just some adjustments and further experiments....
this is typical of actual experiments into unknown regions.
the coming months, Eagleworks plans to upgrade their equipment to higher power levels, use vacuum-capable RF amplifiers with power ranges of up to 125 W, and design a new tapered cavity analytically determined to be in the 0.1 N/kW region. The test article will be subjected to independent verification and validation  at  Glenn Research Center , the ]Jet Propulsion Laboratory , and the Johns Hopkins University  Applied Physics Laboratory [14
sorry it does not meet your higher "experimental sanitation" standards ,perhaps you should apply for a consulting Job over there and show them how its done??
We do have some acquaintances over there...I'll put in a word for you ?
PLEASE ??
thx
Chet
Thanks Grandma
MarkE
Quote from: ramset on December 26, 2014, 06:56:30 PM
Mark E
The suggestion was that those experiments provided meaningful data.  The fact is that they did not.  It doesn't matter whether one favors Shawyer's claims or not:  Because the experiments were conducted in an ordinary atmosphere they could not establish whether force acting on the assembly was due to ionized particles in the surrounding atmosphere or the relativistic CoM violations claimed by Shawyer.
No this is typical of experiments with inadequate planning.  The problem was that they had electronics on the unit that were incompatible with the test conditions that they needed to establish.  It is no secret that wet electrolytic capacitors can't handle low pressure environments.
Be as snarky as you want.  I am still waiting for you to show an example of where your group has produced an effective evaluation in the time efficient manner that you claim.
PLEASE ??
thx
Chet
gotoluc
Hi everyone,
I know you're all at the edge of your seats waiting for someone to build a test device and post the results, so today I made an effort to get mine done and as I'm writing this a video demo with basic test results is being uploaded.
I must say even though the video has some interesting results I will ask those who have hope this device is the real thing to please stay calm and not jump to the conclusion this is a free energy device until we have done many more tests and I'm ready to make that claim.
I'll explain a little why I ask this.
When I first tested the device I used the drill press (prime mover) at the slowest speed and when I connected the load it consumed the exact power from the prime mover that the load delivered. So I thought this device isn't working and was going to post the video that way.
However, just before uploading the video I had the idea to try a higher RPM just to see what would happen.  So I went up two speeds and to my surprise it now was delivering power to the load without affecting the prime mover. So then I went up another speed and now it actually uses less power when under load.
So I shot the video of that and at the end of the video I said I would try a higher load resistor to see what happens and used a 12.5 Ohm load instead of the 1 Ohm load and it delivered 30 watts to it but also used 30 watts from the prime mover.
So there's something interesting going on but we need to take our time to better understand it.
Also, some weeks back I posted that I had the feeling this was similar to the ReGen-X effect and after seeing today's results I'm still thinking the very same way. So lets work together in a caring way so we can improve this effect as a group effort.
Link to video demo: https://www.youtube.com/watch?v=QZXFns8PZ38
Help ever hurt never
Luc
Pirate88179
Luc:
I really appreciate your caution in reporting your findings.  Warning folks not to jump to conclusions is always good advice.  I will watch your video, and I look forward to following your work in this area.
Very nice work.
Bill
