Pulse motor build off time.
Started by tinman, November 15, 2014, 01:18:57 AM
MarkE
Quote from: ramset on December 15, 2014, 08:49:45 PM
Here are the final entries
  http://rwgresearch.com/events/pulse-motor-build-off-2014/
I would hate to have to judge this ........
thx
Chet
There is a lot of creative work on display.  Tommey's is still my favorite followed by the second slayer build that throws off sparks.
tinman
Quote from: Dave45 on December 15, 2014, 11:22:05 AM
@Tinman
Thought you might be interested https://www.youtube.com/watch?v=jM0ER3N4Fy0
Thanks Dave.
This is the reason i hunt for the 100 or 80 series motors,as you dont have to do any rewireing,as there already low voltage motors. If you can get a 40 series motor,then they will produce 240 voltas at about 180rpm-->no need for any batteries or inverters then ;).
tinman
Quote from: TommeyLeeReed on December 15, 2014, 10:36:21 PM
MCR,
You're saying that your pulse motor is so efficient, yet you can't even show basic input vs output of power.
I have seen many types of your kind, many of them play around with PLC to change frequency while claiming more efficient running performance. But when tested under real conditions they fail big time.
You have said it in the past that you don't have to show any meters, yet you would toy around like a child with candy and say,"See my meters" :P
It's time to just call you out as I see it, PROVE IT! ;)
My simple pulse motor, yeah simple to me 8)
I used a single 12v battery, no wires running down the wall as your video shows.
I show true BEMF output, not lights coming from a unknown source.
I also did load test from the battery and can say it's around 1-3 amps from the main power source, not meter connected from where ever.
Clearly you got to much to say and very little to back up your words. :o
Anyone can spin a wheel, does not matter how much energy you put in, it's what you get out that really matters.
Most likely those that put in more watts will produce greater output then those that put in less. ;D
I got two last word for you, PROVE IT!
:o
TOM
I have known MCR for many years Tom,and you'd be hard pressed to get close to the efficiency of his machines-and his workmanship is second to none. He has built many many machines ,and shown very accurate P/in P/out meassurements,so he has a good idea as to what each of his machines are doing.
Yours is a good build for sure,and beats mine hand's down-as i just never had the time avaliable to finish it due to working hours.But seems quite hungry on power,for little P/out from the backEMF. But im guessing that it has quite a bit or torque-will you be doing any torque test on it ?.
Good job from all that entered ;)
Dave45
@All - Really great builds
awesome really enjoyed watching
TommeyLeeReed
MCR,
NPD is what you have been doing from the beginning on this forum!
This pulse motor build off is kids games to me, the only reason I join is because some people wanted to see me back up my comments from the past, other then that it was fun.
This is nothing more then a show and tell, the reason I call you out is your false reading as you stated from the beginning and telling everyone else they are distractions.
You may have a few watching your back, but I know many question you're claims from the beginning.
People like you want to believe they have the answer, like someone smoking crack thinking they can fly.
You have been making claims of how efficient your pulse motor is, yet when someone challenge you to shut up with the BS and prove it, you hide like a rat in a hole.
By the way, I could do much better then anyone thinks. That's why for now on I will be doing PMBO every year so you guys will have to work very hard to out do me :o
Good Luck!
8)
