Pulse motor build off time.
Started by tinman, November 15, 2014, 01:18:57 AM
TommeyLeeReed
Hi All,
This is a complete build of this radial pulse engine from the start x8 the speed, no I'm that fast of a builder.
https://www.youtube.com/watch?v=U36pLafn_M8
Tom
ramset
Thanks Grandma
Well heaven forbid if some pulse motor builders actually want to learn something to better their craft so that they can make better pulse motors.  The pursuit of knowledge is not something to be ashamed of and there should never be peer pressure to stay the same and not think about new ideas and learning new things.  When MCR says it's a "distraction" he is just reinforcing the notion that it's "bad" to put your brain in gear and on another level it's also just a stupid mind game.
For example, you can't say "my motor is efficient" without actually stating what you mean when you say that.  It you don't define what you are talking about then it's a meaningless statement.  There is no "delayed Lenz effect" and there is no such thing as "speed under load."  If you keep on repeating these false ideas then you don't advance and you remain in a rut.  These pulse motor issues have been covered many times and they were recently covered in detail on another thread.  Don't listen to clown comments that try to put good knowledge like this down by calling it a "distraction."  Pulse motors are a neat way to learn about pulse circuits and by extension about electronics in general.  Some people can't really handle that, they think that they can build pulse motors by "listening and feeling" but there is a lot more to it than that.  They want to discourage you from learning because the more you learn the further behind they will get.
I suggested some ideas for some innovative pulse motor architectures that some people might want to try for next year's pulse motor build off.  I also suggested that next year's PMBO actually have some kind of design goal in order to up the ante and make the competition more interesting.
When somebody tries to teach you something so you can challenge yourself to do better and continue learning that's a good thing.  Don't listen to people that try to put that down or be dismissive of things like this.  They have another motivation for doing this which should be pretty clear if you think about it.
Anybody that has any questions or thoughts about pulse motors or how the basic electronics work are encouraged to ask those questions.  There are some knowledgeable people around here that will be happy to see if they can answer your questions and help you out.  Do not ever in your life be ashamed of learning.  Don't succumb to foolish counter-productive peer pressure that reinforces bad ideas or wants to directly or indirectly discourage you from learning something new to better yourself.
ramset
Here are the final entries
  http://rwgresearch.com/events/pulse-motor-build-off-2014/
I would hate to have to judge this ........
thx
Chet
Thanks Grandma
TommeyLeeReed
MCR,
You're saying that your pulse motor is so efficient, yet you can't even show basic input vs output of power.
I have seen many types of your kind, many of them play around with PLC to change frequency while claiming more efficient running performance. But when tested under real conditions they fail big time.
You have said it in the past that you don't have to show any meters, yet you would toy around like a child with candy and say,"See my meters" :P
It's time to just call you out as I see it, PROVE IT! ;)
My simple pulse motor, yeah simple to me 8)
I used a single 12v battery, no wires running down the wall as your video shows.
I show true BEMF output, not lights coming from a unknown source.
I also did load test from the battery and can say it's around 1-3 amps from the main power source, not meter connected from where ever.
Clearly you got to much to say and very little to back up your words. :o
Anyone can spin a wheel, does not matter how much energy you put in, it's what you get out that really matters.
Most likely those that put in more watts will produce greater output then those that put in less. ;D
I got two last word for you, PROVE IT!
:o
TOM
