New device - Validated by Hydro turbine electrial engineer as correct
Started by The Eskimo Quinn, November 17, 2014, 04:58:27 AM
The Eskimo Quinn
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
markdansie
Quote from: The Eskimo Quinn on November 17, 2014, 04:58:27 AM
No comments from the author, validated so enjoy
I am the might Mark and I say BS. your calculations are based on a false assumption. The energy used to pump up does not take into account losses and does not translate into stored energy.
Kind regards
Mark
Low-Q
...and without loss you have unity - and then what's the point? When you load it, unity will turn into "under unity".
MarkE
250W applied for 20 hours = 5kWh =18E6J
20k liters of water = 20m3 = 20E3 kg at an average height of 5.5m = 1.078 MJ.
You've got a dismal efficiency of 1.078E6 JOUT/18E6 JIN ~= 6% before you ever get to your turbines.
Some quotes from the document:
"when I say I have perfected a machine that will put out 20 megawatts an hour..."
  "The 250watt per hour  pump..."
"you see Newtonians get stuck on the watts per hour math. It took 20 hours to get the energy correct, so now some idiot Newtonian will say well you have to divide that by twenty to get watts per hour."
"But for the diehard fuckwit Newtonians let's do the math anyway. 32700 Divided 20 hours = 1635 watts per hour, the input was how much per hour?"
What "diehard fuckwit Newtonian" ever talked about "watts per hour" ?  The fuckwits that designed the hydroelectric generator systems that provide Quinn with his electricity, perhaps? I don't think so.
The only fuckwit around here is the author of that document, who cannot seem to grasp the difference between a Watt (a rate of energy use) and a Joule (a quantity of energy).  The term "watts per hour" that he uses constantly in his silly document means something different than what he thinks it means.
http://en.wikipedia.org/wiki/Kilowatt_hour#Misuse_of_watts_per_hour
But we are used to that kind of foolishness around here. Fuckwits, indeed! I laugh at you, Quinn. You are another blowhard false claimant who can't even use the proper units, you just multiply everything together, and if that doesn't work to give you numbers you like ... you divide!
VALIDATED? By whom? How validated? How is a document containing such "fuckwittery" validated by any professional? Watts per hour..... over and over in the "validated" document. The claim of "validation" is just another blowhard lie.
