What's wrong with this
Started by Floor, December 14, 2014, 12:05:50 PM
MarkE
Quote from: minnie on December 31, 2014, 10:31:29 AM
   The way to go is to increase the volume of the vessel, but that requires energy to
    displace the liquid as per Archimedes. So that's a definite no-no!
             John.
Tinman speaks as though he really believes that he has already successfully changed the weight and/or buoyancy of a submersible without changing any:  The total mass of the submersible, the total volume of the submersible, or the density of the surrounding fluid.  Sunday awaits!
minnie
  Flamin' Gallahs,
                     my crystal ball is showing me a Nobel prize winner!!!!!!
                          John.
tinman
Quote from: MarkE on December 31, 2014, 11:00:21 AM
Like i said many time's,the fluid inside the vessle is changed to a gas state. This increases the internal buoyancy volume of the vessle-the vessle rises to the surface. The gas is then returned to a liquid state,and the buoyancy volume once again becomes a negative-the vessle sink's. I am finding it hard to believe as to why this seems so dificult to believe-what laws of physics dose this break?.
Below is a quick crappy sketch. Which vessle(vessle's) has/have the most buoyancy.
Quote from: tinman on December 31, 2014, 11:11:31 AM
The spheres of steel all have the same weight, or rather mass,  and volume, but the addition of water in one of them, and air in another one, will mean that their actual "as filled" weights will be different. And since density is defined as mass/volume, the one with water in it will be the most dense and so will have the least buoyancy. The one with compressed air in it will have slightly less buoyancy than the ones that are completely empty (0 psi).
The one with the 20 liters of water inside will have the _least_ buoyancy.  If you flash the water to steam without letting any escape ... the thing will still have the same mass, therefore the same density, so its buoyancy _will not change_.
Negative 20 psi pressure? Whaaat? How do you get less pressure than a total vacuum (0 psi)?
MarkE
If the volume of all spheres are the same then the buoyant force exerted by a surrounding fluid is the same for each.  If the dry weights of the spheres including their contents are the same then because the buoyant forces are the same, the wet weights are the same for each, and the net buoyancy is the same for each.
As long as there is the same number of moles of H2O and air ( mostly N2 and O2 ) in each sphere the state of the H2O :  solid, liquid, gas, or plasma inside the sphere does not alter any:  the mass, the dry weight, the wet weight, or the buoyancy.
