Delayed Lenz or not?... post your explaination!
Started by gotoluc, December 16, 2014, 07:22:08 PM
minnie
   Lenz delay doesn't make any sense. Someone needs to show an example of
the prediction made by Lenz's law not doing what is expected of it. The late
after effects are something else!
           John.
MarkE
Quote from: minnie on December 19, 2014, 09:31:01 AM
           John.
Lenz' Law is being confused for Faraday's Law of Induction.  And current is being confused for voltage.  Cutting through that, there is a legitimate observation that current induced into a circuit can be out of phase with the inducing magnetic field.  The problem is that the delay amounts to storing energy from the source and returning some of that energy to the source instead of to the load.
Tinman:
In the first half of my posting I stated that my comments were geneic and not directed at anyone in particular.
Mark often makes great succinct technical arguments and makes graphics and I thank him for that.  Here is my version of a short summary of the issues:
1.  With a resistive load on the generator coil, there is no Lenz delay, it's simply impossible.
2.  With a capacitive or inductive reactive load then there is a Lenz drag during the charging phase and then a push when the reactive load discharges its stored energy for a net gain of zero (ignoring losses.)
3.  What has only been mentioned a few times is the "fake out" Lenz delay.  This is when the generator coil and load together dissipate less power when you are making the Lenz delay test as compared to the original configuration.  Less power dissipated by the generator coil + load equals a higher RPM for the rotor.  This is a no-brainer and many beginning experimenters simply failed to make these measurements.
4.  Changes to the mechanical and electrical configuration of the setup when doing a Lenz delay test can inadvertently change the overall average electrical impedance of the pulse motor and where the power flows in the system.  If the impedance goes down the current draw from the power supply will increase and most likely the rotor will speed up.  If the impedance goes up the current draw from the power supply will decrease and most likely the rotor will slow down.  That's what's taking place in the JLN clip that was linked to.  That is another "fake out" and you have to be on your toes to not hoodwink yourself.
When it comes to #4, you might make a change and the rotor speed will in increase by just a few percent.  Something like simply lowering the stresses on the main bearing while rotating at high RPM could cause an effect like this.
What's been happening over the past two years is that many amateur experimenters when working with their pulse motors will say "delayed Lenz effect" when they observe a speed up in the RPM for whatever reason.  They don't actually investigate the real reasons, they just use the blanket term "delayed Lenz effect" when they see a speed up and they are convinced that they have "replicated the effect."
As a generic shout out, guys and gals, you have to do better than this.  Working an investigation together might help where people encourage each other to get the right answers.  You have to think "outside of the box" and in this context thinking "outside of the box" actually means that you do a proper investigation using standard electronics principles and measurement techniques.  You all can do better if you work together and encourage each other to improve your craft.
synchro1
Quote from: MarkE on December 18, 2014, 04:32:34 PM
The explanation of induced voltage and current, and the effects of phase shift between the induced voltage and current that have been labeled with the misnomer "Lenz delay" are quite independent of the implementation specifics.  One post back you asked about ferrite, now you are on about laminations and solid iron.  The physics is independent of the materials.  Properties of any particular material only set coefficients.
" When ferromagnetic materials are used in applications like an iron-core solenoid, the relative permeability gives you an idea of the kind of multiplication of the applied magnetic field that can be achieved by having the ferromagnetic core present. So for an ordinary iron core you might expect a magnification of about 200 compared to the magnetic field produced by the solenoid current with just an air core. This statement has exceptions and limits, since you do reach a saturation magnetization of the iron core quickly, as illustrated in the discussion of hysteresis".
tinman
Quote from: MileHigh on December 19, 2014, 10:52:59 AM
Tinman:
Not sure how the pulse motor side of things came to be in this !!lenz delay!! thread,as it is more directed at a generator or transformer setup.
Like i said,there is a delay,and always has been. It's just that the delay is that small it's not worth noteing. We can look at a pulsed inductors magnetic field like dropping a stone into a pond. We send a pulse of power to the inductor,and a wave(magnetic wave) radiates out from that inductor-just like a wave of water radiates out from the point in the pond where the stone was dropped.The produced wave from the inductor takes time to get to the secondary(generator) coil-just like it takes time for the wave in the water to reach the bank of the pond.That magnetic wave first creates a voltage across that secondary coil,and then followed by current through that coil. Once current starts to build,the generator coil will build a magnetic field that apposes that which created it-but it IS slightly out of phase(delayed) with the field that created it. the greater the distance between the two,the greater the delay.Current flow is what creates and determonds the magnetic field in an inductor-not voltage,and both distance and frequency determonds as to how great the delay between the transmitter and reciever is.
Have you ever been down the beach and watched the wave's roll in?. You get a wave roll up the beach,then roll back down into the ocean. Some times this wave thats rolling back out into the ocean meets the next wave rolling in,and you get a large peak when they meet. But some times you see the wave that is rolling out pass straight through the wave thats rolling in,and both waves continue on in the direction they were flowing-seemingly uninterupted.
