Lenz free generator
tinman
Quote from: Erfinder on September 16, 2016, 11:51:23 AM
Why do you have to ask?  I have made this clear several times.  One would think that you would at the very least try and understand what's being suggested.  I have considered everything you have ever posted, I don't agree with 99 percent of it, I don't have to, and for the same reasons that you don't agree with anything I say.  The thing to recognize is that we don't have to agree on anything while considering suggestions.  What you suggest doesn't work for what I want, period.  You do good work, I have said this in the past, however, voice the opinion that your direction will not get me where I want to be.  Folk don't want what you are offering, but you are really convincing.  I suggest that power cannot be amplified, and the your reaction.....you tell me what you can't know, not even considering why or how such a claim can be made.  You closed the book, your mind's made up, makes me wonder what you are really doing here, not that that's an issue, you're here, and we are at eachothers throats.
The dead guy is Lenz.....he keeps handing you your ass, and will continue to hand it to you till you check yourself.  Your response will be to the effect that I'm stupid, and you are doing the right thing, in accordance with blah blah blah....been there tinman, done that.  There's more, way more.  Open your mind, and if you cannot, don't stand in the way of those who can.
For the same reasons that current drops Brad, it can RISE!  Consider that I know what I am talking about, or continue to assume that I don't, matters little to me.  Your perspective generates buttkiss on my bench, my perspective.....just know I am here because my bench indicates that it's time for me to be here.
It would seem you must have missed my post some time back.
I do not try to defeat lenz. In fact,i try to do the very opposite to that of the thread title.
I try to increase lenz as much as i can,to the point where it exceeds that which created it in the first place.
Brad
allcanadian
The problem I see with Lenz Law seems obvious on the surface.
Law: "Law is a system of rules that are enforced through social institutions to govern behavior".
Think about that... a system of rules to govern behavior... to govern someones behavior and it is very effective isn't it?.
Lenz Law is simply a statement of the obvious concerning certain phenomena and there is no real genius to be found in it... none. No more genius than declaring that which is below me is the Earth and that above me the universe at large. However as we see above the objective of any law is to govern the behavior concerning the rule. As if to say I should behave like a good little boy and not question these things or I may get in trouble. Mean while science tells us we should question everything which leads to a great deal of confusion.
You see it is not so much the Law but the general behavior which is implied concerning this term Law which I find a little disturbing. It has literally nothing to do with the total energy present in any given system and only describes a discrete phenomena within it. Yet many have taken it upon themselves to enforce this Law as if it has universal application to everything. No, I am sorry it does not apply in a universal context and it is only a statement of what should have been obvious to anyone skilled in the art. As if to say if you continue to do this and only this then this is what you can expect to happen.
Myself I'm a bit of a trouble maker and what some old fart happened to believe 100 years ago really doesn't concern me, our future does. Science is not a cult nor is it a pissing contest between juveniles... it is the pursuit of truth.
AC
EMJunkie
Quote from: tinman on September 16, 2016, 12:37:51 PM
Brad
If anyone here is the slightest bit serious about "Free Energy" you should study exactly what Brad  has just said!!!
If you choose to not take this seriously, then you simply do not understand the Science and are wasting everyones time as well as your own!!!
Lenz's is a Magnetic Field, the Magnetic Field is Current, Lenz's Law is Magnetic Field Opposing Magnetic Field - If you dont get this, you need to do your homework!!!
You need to Super Charge Electromagnetic Induction not kill it!!! Use a configuration or a geometry that uses Electromagnetic Induction to Assist in the Induction Process.
Electromagnetic Induction is Energy over Time, Joules per second, without Electromagnetic Induction you dont have anything!
Its the Output to Input Reflection that must be reduced!
@Ron - Did you finish off the WardForce Generator? Did you get any experiments done on it?
   Chris Sykes
       hyiq.org
P.S: Erfinder has thieved his three coil idea as he has with all his work!!!
i_ron
Quote from: EMJunkie on September 16, 2016, 03:59:13 PM
   Chris Sykes
       hyiq.org
Still a work in progress Chris. Just today I reached the point of a first test. I had built it thinking to try Butch's "no gap" model but found out that the flux never went to the top and bottom bars, it was happy just to circulate in the core. So I have chopped it open as you can see by the couple of band aids holding it together now.
The rotor is 3 inches dia., overall width about 7 inches, The basic rotor is a piece of 1 inch key steel with two stacks of 5, 1/8th by 1 inch neos with cast iron shoes
The left core drops of cleanly when I rotate the rotor. There are two cogging spots each side. So will wind some coils for it next week.
Ron
EMJunkie
Quote from: i_ron on September 16, 2016, 07:08:16 PM
Ron
Very Nice Ron!!!
Lots of turns on your Coil, like the shaded Pole Motor, and the MMF will be High, this the Magnetic Field. Start with one Coil at a time, then try 2 later on.
I learnt a lot from my build, no where near as good as yours!!!
   Chris Sykes
       hyiq.org
