Lenz free generator
BorisKrabow
Hi Gyula !   Thank you!  Happy New Year! After the holidays, we will continue to work  :)
     Addition to MLG1 :connect the diode to the coil electrical circuit so as to get energy when the compensator is working.
                      this will avoid design complexity .
     Does this technology work? Good ideas spread at lightning speed .Non Work ideas remain in the archives forever .
     I want to see this generator on Aliexpress inexpensively in 2 months .if this does not happen then I need to publish the following technology.   It's humor   :D   .
      Technology is freely available to all comers without restriction .
       I hope Google translator does not surprise you   .
        Boris
sm0ky2
I would like to take this opportunity to suggest an addition to
Faraday's solution.
Or rather include the inverse set forth by Maxwell's equations.
Reverse Lenz (in the purely electrical sense)
(when you are done laughing continue below)
Consider the force to be the same as that of electrostatic or
magnetic attraction, and consider the portion of Maxwell's equation that
allows this force to hold a negative value.
Now consider the ways in which we encounter the positive side of this force.
Note that the force is always trailing the moving charge.
Now consider the physical placement of a collector that "leads" the moving charge.
In this scenario we have a very real force accelerating the moving charged conductor
in the direction of motion.
Pulling it towards the contact before it arrives
Rather than pulling it backwards during and after contact.
Focus on the situation, don't get lost in the practicality of actually achieving it.
Before we try, we must acknowledge the possibility and the conditions which must occur.
BorisKrabow
Hi sm0ky2 . Your wishes come true in one minute   8) .  Technological humor   :)
skybiker63
Hi Boris, great idea, did you test it allready ?
BorisKrabow
Hi skybiker63 , many researchers have received free energy, but for various reasons do not want to share this information.
  Here is an example of a similar technology, magnets in coils. The author has left this thread .
       https://youtu.be/tTywjqdvfwg?t=250
I hope I will soon have free time and I will be engaged in testing. First in line MLG
