ZERO INPUT, 10 degrees thermal output...Yes,...genuine free energy
Started by TheoriaApophasis, December 22, 2014, 05:54:57 PM
TheoriaApophasis
Explain wireless and particle free energy transfer
check the current yourself
picowatt
Quote from: TheoriaApophasis on January 01, 2015, 10:03:54 PM
Once again, during the magnetization process of a pre-magnet with a magnetizer such as the one in the image you posted, how much current flows thru the pre-magnet and what is the voltage across the poles of the pre-magnet?
TheoriaApophasis
Quote from: picowatt on January 01, 2015, 09:58:36 PM
There are even clues in the image posted.  But let's see how he does on his own...
coherent and polarized via two means son, either coherency without an increase in capacitance,
or coherent and polarized from a discharge with resultant net increase in capacitance.
What did you think "magnetize" MEANS MORON?     Every atom is has its interatomic radius FULL of magneto-dielectricity
even a glass of liquid mercury,..........  so explain the very term "MAGNETIZE"
You cannot, ..........yet you ask about the CURRENT necessary for magnetization.
Current of what material?
Current to achieve WHAT GAUSS range?
Current for Neo Iron Boron?
What sintering?
What shape?
What thickness?
you use the term MAGNETIZATION with no clue as to even what the term means except by proximal DESCRIPTION
like all others, you live with descriptions, not Explanations.
Ive posted this many times before, but youre clueless.
TheoriaApophasis
Quote from: picowatt on January 01, 2015, 10:05:19 PM
What current son, there is no direct contact circuit with the magnet from the magnetizer coils
AGAIN, asshole, explain wireless transfer of capacitance (energy)
you cannot.
picowatt
Quote from: TheoriaApophasis on January 01, 2015, 10:08:28 PM
What sintering?
What shape?
What thickness?
Wow, this question should be very easy to answer for an "expert" such as yourself (you even write books on the subject!)
During the magnetization process of a pre-magnet, with a magnetizer such as the one in the image you posted, how much current flows thru the pre-magnet and what is the voltage across the poles of the pre-magnet?
Feel free to just round off the amps and volts if you want.
And, of course, if you don't know the answer, you can just state that as well...
ADDED:  If you feel you need to know the pre-magnet material, just use the apparent AlNiCo horseshoe that is in the image as an example.  However, feel free to consider the pre-magnet as being any material you desire, if that is easier.
