T-(Shaped) Turbine, Which uses Centrifugal Force
Started by Overunityguide, December 24, 2014, 05:49:39 AM
AB Hammer
Overunityguide
Good videos but I would suggest a battery powered drill to make it a bit more dramatic.  ;)
Alan
Alan
telecom
Quote from: Overunityguide on December 31, 2014, 04:55:13 AM
As promised... Here I have my T-(Shaped) Turbine Test Videos uploaded:
T-(Shaped) Turbine: http://youtu.be/qEvB2qnXFfo
The System Getting MAD: http://youtu.be/zqogukfonM0
It performs beyond my wildest dreams!
You can attach a bicycle type sprocket with a crank to help it rotating faster,
but otherwise it works great!
AB Hammer
Quote from: telecom on December 31, 2014, 11:18:24 AM
When you understand water pumps you will find that most of them are Centrifugal. That is the reason they need primed and the reason I had no doubt that it would pump. The concept of putting generators in the system is what is cool. But will it be enough to be a viable energy supplier? This is what is hoped for.   Here is a link of a search that may give a few more ideas.  I typed in (Centrifugal Water pumps design)
https://www.google.com/search?q=Water+pumps+design&biw=1920&bih=888&source=lnms&tbm=isch&sa=X&ei=yzikVP_7IdivyATz3ICgAw&ved=0CAcQ_AUoAg#tbm=isch&q=Centrifugal+Water+pumps+design&imgdii=_
Alan
Alan
cipbranea
You can start it like this one: https://www.youtube.com/watch?v=ZiMtFWkFgEw. Notice the spinning effect produced by the nozzles.
Overunityguide
Quote from: AB Hammer on December 31, 2014, 01:14:16 PM
Alan
To continue on the comment of AB Hammer, yes the system has the same operating principle as a Centrifugal Pump System. Except for the fact that a Centrifugal Pump its impeller is normally fully submerged under water. (which creates a lot of resistance) In case of the T-(Shaped) Turbine Concept, about 98% of the System is running above the water, what's also a good thing in my opinion...
