New Free Energy Conferences in Hamburg and Chicago
Started by rickfriedrich, January 05, 2015, 08:45:12 PM
jonfrommanahawkin1
gold plating has more to do with transfer of potentials then it does corrosion inheritance, because if it was a matter of corrosion then much cheaper materials would be used like chrome or  nickel
one hundred years of audio design and techniques cant be wrong, right? but they could be wrong because they havent met you fine bunch of prestigious science folk
why do you think gold is only on connectors not integrated into wires and boards exc.
but you guys know best and all the big businesses of the audio industry are trying to rip us off, i should have seen it coming when i spent all that money on that microphone and connectors......i could have saved hundreds and just used the one that came with my computer the sound is just the same, and all those musicians  should have know... its all the same in the end....
*sadface*
MarkE
Quote from: jonfrommanahawkin1 on February 14, 2015, 05:46:41 AM
Nickel is used both as a surface finish on many 1/4" phone plugs and as a barrier layer for gold plating.
If you had researched you would have answered your own question and corrected your misconception.
Gold over electroless nickel is a common PCB surface finish for equipment that has to last.  Soldermask over bare copper and tin, or silver finishes are common on low cost consumer goods that don't have a long life expectancy.
$579. for a 6' HDMI cable is very strong evidence that at least some in the industry try to fleece the gullible.
*sadface*
jonfrommanahawkin1
im not even going to justify that with a response .....your just dumb
memoryman
from Bestbuy:
AudioQuest - Coffee 6.6' HDMI Cable - Brown/Black
Model: 65-081-03 SKU: 1267646 Customer Rating:  4.6  (16 customer reviews)
$695.99
$700!!!!
Correction, Mark. In the CNC field, all pcb's use just solder resist over copper ; these are industrial boards' I have designed many boards and sell the products; never use gold plating for traces.
memoryman
Correction: you can spend much more:
AudioQuest - Coffee 39.4' HDMI Cable - White
Model: 65-082-09 SKU: 1267764
From our expanded online assortment; compatible with most HDMI-enabled devices; silver-plated long-grain copper conductors; Dielectric-Bias System; audio return channel enabled
   4.7  (34 Reviews)
Check Shipping & Availability
$2,200.99
Go to Amazon and you'll find:
AudioQuest Diamond 16m (52.49 feet) Braided HDMI Cable
by Audioquest
$13,499.75
Only 4 left in stock - order soon.
FREE Shipping
3.6 out of 5 stars 49
you do get free shipping to reduce the pain...
