EMJunkie
Quote from: Red_Sunset on May 03, 2015, 05:35:08 AM
MH & Mark,
Chris and Enjoykin have plenty to say, it is just a different kind of say.
As I alluded to in my previous mail (current limit required, you have a bug in your timing diagram.
I am sure this is not what you intended.  Your starting condition would be a current limited short circuit current though the 2 coils (resistance=0).  Applying power and applying signal are 2 separate actions
A short summary without calculations,
1..  At power-up, the current and mag field in both coils would be max.(TP1=0v)
2..  You fire the Mosfet, this shorts the H1 coil (coils are not coupled, so there is no feedback to 2H)
3..  1H will produce a EMF that will be dissipated through the mosfet protection diode (TP1=diode junction voltage)
4..   At this point, the current limit of the power supply set to 1A will save the mosfet.(TP1=~0v, mosfet conduct voltage)
5..   Mosfet opens and current flow starts in 1H, presenting itself as a high impedance
6..   This initial hi impedance is noted also by 2H due to reduced current flow
7..   2H will up the voltage with an induced emf spike at TP2
I leave the value calculations to you
Red_Sunset
There is no bug in the diagram and there is no current limit.  So it's kind of a non-starter.  But the real reason I am posting is to request once again that you mark up the timing diagram and also please do your own calculations when you have the time.  For the way I personally think, a text description like that is more confusing than clear and I have to read it 10 times just to figure out what you are trying to say.
Chris:
You know, I think it's like this:  Many of us if we had a newspaper in our hands, we would be tempted to whack you across the side of the head with it.
You want to know a new definition of stupidity?  If you have been following the US news you should be able to relate.  Stupidity is running up and cutting a fire hose with a knife when the firemen are out there trying to put out a fire.  That is really really stupid.  The way you are acting right now, you are almost as stupid as that guy.
EMJunkie
MarkE
Quote from: MileHigh on May 03, 2015, 06:49:20 AM
It may not be clear that everything starts at T0.  Red Sunset may be incorrectly assuming that the 1V had been applied for some prior indefinite time, in which case the current would be undefined.  Here is the diagram with a switch added to make clear that the circuit is idle prior to T0.  The switch has zero resistance, zero inductance, zero parasitic capacitance, infinite open circuit resistance and switches instantly.
