0 Members and 118 Guests are viewing this topic.
EMJunkie
Quote from: alan on January 20, 2015, 07:17:16 AM
Hi Chris,
Do you now understand Leedskalnin pmh? :)
Please come to this forum
http://open-source-energy.org/?board=4.0
Hi Alan,
Yes was video No#3 a little over 5 Years ago - see: https://www.youtube.com/user/SweetSQM/videos
I am short on time. I am happy if you cross post my posts there. Its up to you?
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
wistiti
Hi Em!
Did you find the ideal place to put the gap in the magnetic frame path? Mabe betwin the primary and the secondary... or in the middle of the 2 parthner coil?...
I read your pdf but as you can see i have not quite understand everything... Still learninr a bit each day! :)
Thank you!
ps: sorry for my english. ;)
EMJunkie
Hi Wistiti,
Quote from: wistiti on January 20, 2015, 03:24:01 PM
Good Question!
Gaps are more important in one configuration compared to the other!
If one has two coils the same and one is NOT wound in the opposite direction, then a bigger gap will be required! Other than that, one can get away with no substantial Gap! Simply spacing the coils appropriate distance apart may be enough! Sometimes one can have the Partnered Output Coils on top of each other like I have shown in some of my devices.
Follow your Gut Feeling, it will lead you in the right direction!
Please feel free to ask questions! No Question is a Silly Question!
The only question that is silly, is the Question not asked!
Thank you!
No Problem! Just doing my bit for the Species!
I understand your English perfectly!
Kind Regards
EMJunkie
Quote from: EMJunkie on January 19, 2015, 03:52:26 AM
@ALL
Can anyone tell my why Loose Coupling or a Leakage Inductance is necessary? The answer is in one of the Videos posted in the first post to this thread!
Kind Regards
@ALL
Answer: The Magnetic Field in each Partnered Output Coil must be given the time to build up! A Loose Coupling or a Leakage Inductance gives the Partnered Output Coils a little bit of room for the Fields to build! So each Field can support its Partner!
Please check back on this post as I may edit it if I can think of a better way to explain this.
Kind Regards
wistiti
one other question; does the magnetic core have to be a kind of a looped one like ring or square for a good return magnetic path? Or it can work to with a straight one like a  ferrite rod?
