0 Members and 60 Guests are viewing this topic.
Enjoykin2017
Quote from: EMJunkie on September 20, 2016, 08:37:02 PM
I really was hoping others would show their work and then we could ALL work towards a common goal, move ahead...
Seems no one is interested in this important stuff?
   Chris Sykes
       hyiq.org
Yes EMjunkie seems me too - no one interested in Free Energy and Free Freedom !!  :o
But .... to continue interesting experimental story !!
EMjunkie and who is interesting listen (read) carefully. On a copper tube was wound non-inductive winding (form of stacked packing partnered coils) , which covered a part of tube surface , having left at the same distances, parts of tube on both sides from winding ends. The winding wasn't galvanic connected to a copper tube on which it was mounted. The winding was wound by enameled copper wire diameter 0.5 mm.
On a non-inductive winding was given very high current - about several hundreds of amperes - enough current for certainly inevitably destroy wire under such conditions.
But what was happened there was one BIG MR. NO !! :)
Copper tube withouth non-inductive winding was destroyed , but only before winding start and after a winding end. The segment of copper tube on which this non-inductive winding was wound  , remained absolutely safe and not dameged , while the non-inductive winding didn't heat up at all !!
Terminal parts of copper tube, free from non-inductive winding cover ,  were heated up to red heat temperature as a result of influence high short-circuited currents.
Parts of a tube which were covered by winding remained at same temperature what was before current feeding. Non-inductiv windings didn't heat up at all !!
It is obvious that high current which destroyed copper tube and heated free tube ends to red heat , was behaved according to the Joule-Lenz law , but it is also obvious that on a tube section covered by non-inductive partnered windings the same Joule-Lenz law didn't work !!
From these experimental observations is useful to draw some practical conclusions.
1. Tube section which wasn't submitted to influence of Joule-Lenz law (covered and protected by Non-inductiv partnered windings) ,  practically didn't radiated heat , while huge current was running though non-inductive partnered windings.
2.  Free tube sections which were submitted to influence of Joule-Lenz were subjected to thermal overheating and , even to thermal corrupting !!
3. Magnetic-field is directly responsible for thermal radiation and red heating.
4. Final conclusion is simple : non-inductive winding in form of stacked packing partnered coils was a Joule-Lenz LAW-BREAKER !!
ps: Folks - you should be very happy and run a lot of interesting experimenst !!  :D
Good Luck all
Enjoykin
Key word: non-inductive winding
The non-inductive winding is a such winding which rounds , are located in space in such manner that currents in adjacent rounds flow towards each other. Respectively , magnetic fluxes of adjacent rounds are opposite directed , so, the winding has practically , no external magnetic flux and , as a result of it , has very small inductivity – inductivity not appropriate to geometrical form of this winding.
EMJunkie
Thanks Enjoykin! Yes some interesting results can be obtained!
@ALL - I would like to point out, shown above, one of the Coils will assist in the Inputs action, which one?
   Chris Sykes
       hyiq.org
Jeg
Thanks for the report Enjoykin. It seems that eddy currents are neutralized across the two opposite winding. Something that can not happen at the ends of the tube (which obviously doesn't have any slit across its length). I guess that inside of such a tube with non inductive winding as you call it, if someone let a magnet in free fall, magnet won't experience any drag like here. https://www.youtube.com/watch?v=5BeFoz3Ypo4
shylo
Hi Enjoykin, I don't understand what is a non-inductive winding?
Sounds like the winding just pushed all the eddy currents out to the ends of the tube ,didn't break Lenz law
just redirected it?
Thanks artv
gyvulys666
interesting what will happen if u use Enjoykin coil setup on cooper tube which have shape of toroid and   this toroid all covered with this coil setup? :)nothing or something?:)[/size]
