0 Members and 57 Guests are viewing this topic.
wistiti
Hi Lostfox!
For now i have just the time to do a few test with the coil on the toroid as the primary (120vac). This way depend of the center leg POC connection i have 16v or 32v at the output... I have more configuration to try... For sure i will also try it the other way, center poc as primary and toroid as secondary... :)
To be continued...  ;)
wistiti
EMJunkie
@Wistiti - Looking Good! This idea reminds me of another device: am-fm chaotic self-organized oscillator from a 3ph solid state rotoverter
Gustavo Roveran's channel has a lot of good videos.
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: arhitrade on November 14, 2016, 04:41:23 AM
The use of Delay Lines to increase efficiency - http://gorchilin.com/articles/ideas/delay?lang=en
Thanks Arhitrade! This is a fantastic Article!
I am still reading and studding the Math, but I already see that we have seen some of this already. It is clear that the thinking behind this article is the same, as you have pointed out. We are looking at two Power Sources.
   P1
   P2
Each quantity is the direct result of Ohms Law: Power P = Current (I)2 x Resistance (R)
It is pointed out that the Impedance (Z) is a factor of this power output, which is the combination of DC and AC Resistances, AC Resistance is the Reactance (X), which both Coils will have.
The Voltage Source's are defined as:
   U1
   U2
We see an equation that we have covered before:
   da+/dt + da-/dt = I
Where (a) is the angle, or direction indicated by the Current, Positive or Negative. This equation brings the same result as:
   I1 + I2
extending:
   (I1 + I2)2 * R = Pg
which is the same as:
   Ig2 * R = Pg
Which is Ohms Law. The Capacity that is mentioned (Kη2) is an interesting addition, perhaps something I have been missing for all this time. Any Math Guru's, I would really like to hear any comments you might have hear?
   Chris Sykes
       hyiq.org
P.S: All here should see that LDL2 is in implementation of the Tariel Kapanadze Device:
EMJunkie
I want to make a point of this as there is a lot of very good reasoning behind the ideas and concepts:
@Giantkiller - The thread you started has solid foundation! You have the right concepts in your head, how do I know? I started in a very similar area.
See: LTPU Center Toroid Breakout
When Electromagnetic Induction occurs, there is initially a Voltage Potential gained, there can be no Current, unless a Load is applied, and then a Current will flow, this process can not work the other way.
When Electromagnetic Induction occurs, if there is no Voltage, then there can be no Current.
Do the Magnetic Fields Buck in an Electromagnetic "Generator"? - Yes, the Magnetic Fields oppose on Rotor approach to the Stator, the Fields Buck - But not how Conventionally Bucking is defined or understood! Simply because typically there is No Voltage Potential, if there was, then this would be a different storey! Sharp Pulses can do this!
There is another way, its easier to understand and it starts with Floyd Sweets Equation mentioned above, and the MrPreva Circuit shows how this works.
Remember, the Magnetic Field is Current and Current is the Magnetic Field, Current directions oppose, Magnetic Fields Oppose!
See:
   Chris Sykes
       hyiq.org
