0 Members and 101 Guests are viewing this topic.
shylo
Hi Chris, you said,
"So, here we see, again, yes I know, that the Magnetic Force is responsible for Electromagnetic Induction, and also is the cause of Drag on the Rotor, Lenz's Law. But we are Engineering a Machine to work for us, not against us. Lenz's Law is Engineerable, we just have to be on the right side of the Magnetic Field,"
You nailed it.
artv
EMJunkie
Quote from: partzman on December 30, 2016, 10:22:55 AM
Wow Chris.  What led to this tirade of yours?  I'm one of those "dummies" from OUR who takes my research seriously along with others on that forum and I for one am willing to correct the error of my ways!  So please, show me just one 'documented' POC (proof of concept) of an OU device.  I'm not interested in videos claiming this or that, pencil drawings w/math, theories, hearsay and the like, but documentation of a valid OU device that has been replicated or is able to be replicated and I will fall into line!
pm
Partzman - No, you're not "one of those dummies", you led many for a long time! Did all the hard work for others.
Then took your work to a private bench because others persuaded you to, so there was no benefit to the community, just to those that have private access to your private bench.
I believe we are seeing some sort of pattern here now...
I most certainly do not expect anyone to "Fall into Line"! I expect people to use common sense, to make educated decisions. Logical decisions.
The world was shown the best demonstration, with the top of the line "Measurement Equipment" by a skilled and experienced Electrical Engineer - Yes, Graham Gunderson - Yet you of all people ask for proof?
I cannot show you proof of this level, I have budget equipment, my Electrical Engineering Skills are not at Gunderson's Level, I have, however shown for many years proof of concepts, using the exact same configurations, yet you still ask for proof?
YOU are all letting these technologies slip away from you - YOU need to study this with all you have, never let this get away from you like you starting to.
THIS IS SO IMPORTANT!!!
It is the Time Rate of Change between the Coils, which is Electromagnetic Induction that Pumps the Energy we are looking for! It is the Third Coil and the Magnetic Field from it that reduces the direct effect of Lenz's Law back on the Primary Coil which opens the door to increase in Output to Input.
   Chris Sykes
       hyiq.org
P.S: I am very happy to see that this post has stirred up the Pot and got some attention!!! Like I said, this is very important! Our technology is slowly moving away from Transformers and Coils as we see today, moving into solid-state switching and so on, much change we have seen already!!!
The next generation will know very little, and have nearly no experience with Transformers and so on, just like we today have little experience with Magnetic Amplifiers and Saturable Reactors!!!
It is NOW or never!!!
EMJunkie
Quote from: shylo on December 30, 2016, 01:07:21 PM
Hi Chris, you said,
You nailed it.
artv
Hi ArtV - Thank you, I am happy this has helped!
Maybe for others a little more explanation might help? From Richard Feynmann:
So you see, that the real Energy change is the Negative of the Mechanical Work, and that's why I keep writing this as EArtificial, because the true Energy of the world, is the Negative of EArtificial, in this case is μ.B - I just want to point out that difference in Sign, but that's just interesting.
One could use this statement as a parallel between "Energy" and the Magnetic Fields. For any Magnetic Field, in a configuration that Energy "Generation" is involved in, there is always two sides, or signs, one + and one -
One could relate this to the Night Side of Nature and the Day Side of Nature, or the Forces of Dark and Light...  I have posted many times the image of Yin Yang:
In Chinese philosophy, yin and yang (also yin-yang or yin yang, 陰陽 yīnyáng "dark—bright") describe how seemingly opposite or contrary forces may actually be complementary, interconnected, and interdependent in the natural world, and how they may give rise to each other as they interrelate to one another.
So an opposition to everything in Nature exists, an Equilibrium, the solution to the missing Chaos, is Balance.
Changing this "Equilibrium" is the goal. Using one Magnetic Force to invoke another is common, but using a third Magnetic Field to "Counter-Act" the opposing forces is not common. This is what we are introducing. Partnered Output Coils, a concept all the Greats Used!
For PartzMan as well:
The feedback loop: Previously mentioned, you will more clearly see how the loop functions at the time you see the physical construction of the stationary armature of stator assembly. The underlying principal (forget Millikan's experiment) has been derived in that magnetic effects vary on the square of the current. As the load on the machine increases, the volt-ampere product increases. The rate of flow of charges increases. Quantum mechanics state not all electrons in copper are free to carry charges. Then it's time to set the wheels in motion to free them from binding magnetic forces. Once this is done, conductivity will improve and resistance decrease as we are dealing only with electrons. Copper will not change to another metal as atoms which are mostly empty space would have many electrons to spare anyway.
Electrical Energy IS the Electrons inside the Copper Conductor, the Copper Wire IS our Battery, the Source of Energy, we ONLY have to make this Energy Move Efficiently, this is our Job as Engineers, Engineering Lenz's Law, to Free Electrons and get them Flowing, Current (I), which is done by the Change of the Magnetic Field: Electromagnetic Induction.
   Chris Sykes
       hyiq.org
EMJunkie
If the Total Electromagnetic Induction is not great enough in the Action, then this does not work!
Throwing a few coils on a Core and Pulsing one is often not enough to make astounding results. It is the combination of many variables, some seem to currently unknown, but Electromagnetic Induction has the following main variables:
   1: The Magnetic Field (B in Gauss (CGS system), or today B in Tesla (MKS system))
   2: Frequency (Time Rate of Change or the Magnetic Field)
   3: Cross Sectional Area (A = π r²) or (A = l x w)
   4: Turns (N Turns of the Conductor)
Unknown is the Turns Ratio that best fits this combination, some turns ratio seems to be better than others. Maybe this is 1/4 Wavelength thing, I am not sure. Frequency Response also plays a role. Core Materials can change how this works.
Floyd Sweet referred to the Common Transformer Equation:
   N = ( E x 108 / 4.44 x B x A x f ) x 1.11 (an Empirical Factor derived by Floyd Sweet)
It is worth noting, many will already know, but this 1.11 is already applied in the 4.44, which is 4 x 1.11 as Empirical Form Factor well known in Transformer theory. Where 4 is for Square Wave Transformers, 4.44 for Sine Wave Transformers.
This equation is also derived from Faradays Law Equations: https://en.wikipedia.org/wiki/Transformer
   Chris Sykes
       hyiq.org
EMJunkie
Happy New Year!!!
May 2017 be OUR Year, not OUR's, but you, and you, and you and you. All of us!!!
Sorry a bad joke in light of recent posts...
Quote from: The Sea of Energy in Which the Earth Floats - By T. Henry Moray, D. Sc.
If one considers that an electrical generator is not in the true sense a generator - as electricity is not made by the generator - but is merely an electrical pump, the Moray Radiant Energy device may then be referred to as a cosmic ray pump; that is, a high speed electron oscillator serving as a detector of cosmic radiations which causes a pumping action of surging within its circuitry.
Quote from: Floyd Sweet
The number of turns per coil is determined by Faraday's law as quantized by Neumann.
Happy New Year!!!
   Chris Sykes
       hyiq.org
