Minato Motor Modification
Started by juspot82, September 25, 2006, 01:29:15 PM
Dingus Mungus
Quote from: juspot82 on September 27, 2006, 05:22:16 PM
Ok....what about instead of the electromagnet kicker you use one of the following:
1. Instead of a balanced wheel make it heavier near the first magnet on the wheel where the lock up occurs. Since the wheel stops due to the repulsive force of the first magnet coming back around to the starting position. If the wheel is off balance just enough, then the rotational force should be enough to carry it into another rotation. The shaft would require extra bracing and the bearings would probably wear out faster, but it could produce over unity.
2. If a weighted flywheel approach doesn't do it then what about a single set of attacting magnets. The lock up is cause by the repulsive force being too great to overcome. What if you add a rotor onto the shaft positioned above the wheel at the lockup point with an equal attraction force to a stationary magnet. That should create a "dead zone" where the repulsive force on the wheel equals the attractive force on the rotor and allow conservation of momentum on the wheel to continue the spin. By dead zone, I don't mean a way to eliminate the flux, just equalize it in both directions. Once the 2nd magnet on the wheel passes the lock up point then the repulsive force should be great enough to cause another rotation. If needed a stronger set of magnets can be used for the rotor.
I have though about both of these ideas...
1) If the weight is combined with gravity to pass the cog point then the device must then lift the weight against gravity to reset it, which is a loss of power. If the wheel had enough monentum to lift the weight it would also have enough monentum to pass the cog point.
2) You would just lose your cog point and gain a sticky point, both are equal in their ability to create points of equalibrium.
juspot82
Quote from: Dingus Mungus on September 27, 2006, 05:50:03 PM
1) I'm not talking about a gravity assist. Just a slightly off balance horizontal wheel.
2) The cog point is on top of or below the sticky point depending on how you build it. They should cancel eachother out and allow the momentum of the wheel to finish the job.
Dingus Mungus
Quote from: juspot82 on September 27, 2006, 05:54:15 PM
1) off balance (more mass on one side) on a horizontal or vertical wheel?
2) The next stator magnet would then become the cog point.
juspot82
1) Horizontal wheel.....it would have a lope to it similar to a big block engine with a performance cam. As long as the ring of magnets lopes the same ammount you should be in good shape. Only downside is the added wear and tear of having the system unbalanced.
2) Adding a second attracting magnet should do the trick. Place them on a "V" shaped rotor almost side by side like the wheel magnets....or "Y" shape if you want to counter balance it with a dead weight on the end of the Y. Once the second attracting magnet passes the sticky point then the repulsive forces in the positive direction should outweigh the negative repulsion and attraction forces. It takes the 3rd wheel magnet passing the cog point to complete the change over for the 2 attracting magnets to be out of range and prevent negative feedback. But from what I can see, until the 3rd magnet passes all repulsive/attractive forces should be equal and allow momentum to take over.
Dingus Mungus
Quote from: juspot82 on September 27, 2006, 06:29:07 PM
1) I dont understand what you mean by "lope"  ???
http://www.answers.com/lope&r=67
Do you mean unbalanced with mass or flux density?
(mass unbalance on a horizontal wheel only creates vibration and loss)
(spiral magentic wheels are unbalanced flux by design)
2) If the perpose of each attracted magnet pair is to "create a dead zone" (your words), and you only need to add "dead zone"s to the first two stators, then you would be able to just remove the first two stator magnet sets (atractive and repulsive) and it should still function without the magnetic "dead zones" right?
I'm not trying to knock your ideas but I've been studying magnetic motors/PMM's for many years, and I'm simply passing on things I have observed already. Maybe if you created some rigid models of your ideas in FEMM/Paint/flash to test/show the ideas in a more complete thought. At this point though you've modified your original concept 2 or more times and it seems more like grasping at straws then conveying acurate information... no offense.
http://femm.foster-miller.net/
http://isohunt.com/torrents/flash?ihs1=5&iho1=d&iht=5
