Universal Engine offer ,unlimited power from centripetal force [a spinny thing]
Started by ramset, February 17, 2015, 03:58:57 PM
vince
http://youtu.be/lFornDBZsJY
Some of you might remember my dabbling in this subject in the double pendulum thread last year. I unfortunately did not go any further with this experiment because of many reasons but i did determine that there is a definite radial force component to the spinning pendulum that can be harnesed with one way bearings.  i did buy some parts to modify my design to add a one way bearing and a separate output shaft and might pursue this when we get out of this deep freeze we are in.
whether this harvested centrifugal force from the rotating pendulum is usefull in adding to the output power of the prime mover has yet to be determined but From my experiment I believe there may be something to his design.
Vince
gotoluc
I remember your experiments on this Vince
If the established science cannot fully explain gravity then there may be a chance there's an effect that can be used to our advantage.
Looking forward to more on this
Thanks for starting the topic Chet
Luc
RomanEmpire
Hi Vince!, I all, I'm Italian so i apologize in advance for my non correct English
I had had the same idea for the motor and I thank you for sharing your experiences. I have a question to ask: Why do you use the one way clutch gear and not entrust the collection of the work to a DC generator with a bridge rectifier? I like this idea because the energy generated and the collection of it does not affect the primary movement and do not involve an extra effort. I had thought of a different assembly (i attach an explanatory drawing very rough that I was just doing lately). I think we can get a good result but  must calculated and tried with different weights and different lengths of the arms properly coupled to the rotational speed in order to optimize the device, I thought especially for a good length of the arms combined with a movement not continuous but eventually made of synchronized pulses of the primary motor. I have not yet put anything into practice because I have technical difficulties and I'm not very good, I'll try to implement something, but at the moment I can not share anything concrete unfortunately. I gladly follow closely future developments
