OVERUNITY CIRCUIT ??
Started by magnetman12003, March 09, 2015, 05:30:10 PM
magnetman12003
Hi All,
Here is a circuit I put together that allows a small electrical force to transform into a large electrical force.
The transistor and coil take 24 volts and low amps to operate.  When that happens a 2 inch diametric ring magnet with huge flux lines starts spinning over the coil.
The flux lines cut through the coil and generate hi frequency, hi power voltage and current.
That is sent to a full wave rectifier circuit that turns it into DC voltage and enough current that could kill you. A capacitor stores the charge.
The NEGATIVE terminal is common to both input and output.
So a little bit of electrical energy produces a lot of electrical energy using mechanical action or magnet spin.
Double click the diagram for a larger view.
https://web.mail.comcast.net/service/home/~/?auth=co&loc=en_US&id=1070313&part=2
Void
Hi magnetman12003. That link appears to require some sort of login to access.
It is not working for me anyway. Appears to be a link to a private email account?
All the best...
FatBird
I'm getting an ERROR Message when I click on your link
deslomeslager
(as it seems) the login is Zimbra and the pass (it is in the url) is 1070313
But: Jetty (the server) then says "account is not active: Zimbra".
FatBird
