OVERUNITY CIRCUIT ??
Started by magnetman12003, March 09, 2015, 05:30:10 PM
magnetman12003
Quote from: Void on March 20, 2015, 05:17:53 AM
@magnetman12003:
I believe you are using twisted pair cross connect (bell wire) for L1 and L2, but you say have
them wound as inner and outer windings? I don't get how the two wires  for L1 and L2 can be a twisted pair,
but be wound as separate inner and outer windings? Can you clarify?
What are you using for a load to test with?
When your load is connected, what is the input current draw from the 24VDC power supply?
All the best...
L1 and L2 are already wound twisted together right on the factory spool.  L1 being one wire and L2 the other wire.  A pair with 4 ends and one continuous twisted length winding on the spool. Inner winding is the pair of wires that start first on the spool core.  The outer pair of wires finishes on the outside of the spool. The wires are color coded already with PVC
insulation from the factory.  The input current draw is 1/2 amp.
magnetman12003
Quote from: Groundloop on March 22, 2015, 03:31:14 AM
Hi Magnetman,
Thank you for posting information about the coils. I have corrected my drawing of your circuit
and attached the new drawing here.
Alex.
Hi Alex,
Can you send me your easy to understand circuit link to me at 65t@comcast.net   I am unable to make a copy of it from the Over unity posting.
magnetman12003
Quote from: yg_34 on March 22, 2015, 06:38:50 AM
As I remember it should be this
https://www.youtube.com/watch?v=nyTxYD_pYic
You are correct.  That's what the coil looks like and I have the magnet spinning over the coil.
You don't need a circuit switch.   Flip the magnet with your finger and the circuit is powered automatically.  Stop the magnet by taking it away from the coil and the circuit stops.
Void
Quote from: magnetman12003 on March 22, 2015, 03:06:37 PM
Thanks mate.
All the best
Quote from: magnetman12003 on March 22, 2015, 04:14:51 PM
Hi Alex,
What happens when you click on the attachment link, below the image? Doesn't your computer give you the option to save the file when you do that?
You can also use any of a number of different programs to make a screenshot capture of anything that is displayed on your computer screen.
