Thermionic Overunity Generator my gift to the world.
Started by Arthur1, March 31, 2015, 02:03:48 AM
profitis
Markscoffman:'Yeah, the two worlds act as though they are totally isolated, which they are'
Until they are correctly juxtaposed they remain isolated yes.its like a safe with a turny knob,you turnit the non-quantum knob until you clickit direct on the quantum treasures,then you stay in that loop and manipulate,as rossi and co are now doing.if there is a hysteresis loop in this guys vacuo-tube then it may work.do you see a hysteresis loop in this layout markscoffman
profitis
Pomodoro:'Let's assume the device works and electrons hit the plate. Do they power the load or heat up the plate?'
Both.reduce R your load and heat may go up?or vise versa?do you see a hysteresis loop here?bear in mind that an electric field can manipulate work-function of the emitter
joel321
Quote"The grid could get damaged from excessive current"
LOL, yeah.
https://youtu.be/QuE--xlkTYk
Pirate88179
Vladokv
There I will share link for true termionic OU generator, which requieres no any input of energy, experimentaly tested!
Also by its detailed description is obivious how to replicate and on which principles it operates.
http://www.mediafire.com/view/w3jvt0z3336f9h7/Maksvelov%20demon%20pobedjen.pdf
Device can be improved by using metall plates with different work functions opposing each other instead magnetic field!
Using Wolfram metall  (Electon capturer - high eV) coated with recomended Ag-O-C legure on bottom, kann be stacked one on top of other in vaccum only separated by isolating poles(columns) or any other isolating spacer
